Page 1 of 9 123456 ... LastLast
Results 1 to 10 of 81
    Jan 2009
    Southern california
    Default Operators manual for Airco welder
    Im looking for operators manual and wiring diagram for an Airco welder model No 3A-DDR 224 HPA/BD SN S423575. I believe it was made by Miller. ( it has parts that are similar to parts in my Dialarc HF-P and some are labeled Miler) Can anyone direct me to a source? Thanks!
    Appleton, WI
    424
    cessna195,
    I checked my cross reference chart and it looks like the unit you have there crosses over to a 330 A/B/SP, the S serial number would be a 1967 model. You can contact our manuals department at (920)-735-4356 to see if the manual is still available.
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
    Dec 2008
    9
    Default Looking for manual also
    I too am looking for some literature for an Airco welder. The model # looks to be the same (3A/DDR-224 HPA/B-D), but the Serial number looks a little different, it is 72-604573, and the stock # is 1341-0118. Does this welder also cross with the same Miller welder (330 A/B/SP)?
    Thanks,
    Justin
    Nov 2003
    3,845
    Default Pdf
    Cesna195
    try this link and see how close this manual is
    http://www.millerwelds.com/om/o340d_mil.pdf
    this is for a 1975 vintage machine ,,, was unable to retrieve one that matched your serial...
    off topic: C195s are one of the prettiest birds out there... that Jacobs Radial makes a unique song that you can tell for a long distance... have not heard one in a lotta years.. (there was a polished and turquoise one in ABQ years ago... until the owner groundlooped it... too bad)
    hope this helps
    Heiti
    Appleton, WI
    424
    Justin,
    Your machine crosses over to a Miller 330 A/BP Miller with a stock number of 901041. It was built in in the first half of 1972. You can contact our manuals department at (920)-735-4356 to see if the manual is still available.
    Kevin Schuh
    Service Technician
    Jun 2010
    3
    Default Airco Literature?
    The model # 2.2 ADG-AMEL-A
    and Serial number is: S435310
    Thanks,
    Dean
    Appleton, WI
    424
    Dean,
    I could not find a 2.2 ADG-AMEL-A in my cross reference, could it be a 2.25?
    Kevin Schuh
    Service Technician
    Jun 2010
    3
    I'll have to check - it's a gas powered unit - would 2.25 make sense with the rest of the numbers?
    225 Amp A.C. "Wasp"
    Weld and Power Generator
    Air Reduction
    N.Y., N.Y., USA
    The engine is:
    Onan - Division of Studebaker Corp.
    Model - CCK-MS/1196G
    Serial - 117CA04386
    Appleton, WI
    424
    Yes, that would make sense with the rest of the description. The 2.25 model crosses over to a Miller AEA-200 LE engine drive. The "S" serial number puts it at a 1967 model.
    Kevin Schuh
    Service Technician
    Jun 2010
    I'm also looking for some info on an Airco welder.
    It was advertised on a local buy an sell. This is all the info I have.
    450 Amp Airco Mig
    Airco RG909001.
    Any help would be really appreciated.
    Here's the attached picture,
