Results 1 to 3 of 3
    Sep 2007
    Medford MA
    524
    Default Latest bit of garden art
    Over the summer we found a mess of old barrel hoops - more rust than
    steel, no doubt. A few weeks ago I turned them into two of these
    (I only took a picture of it during a recent snow storm, and just uploaded
    them now... I know, I'm lame... )
    A friend recently gave me an old AC225 he had no need for, so I
    figured I'd use that to weld them together. I really had not done much
    stick, other than one night in an adult ed course I took over a year ago.
    All I can say is that it's a good thing that I didn't get a picture of the
    beads... they'd be embarrassing and you guys would laugh me off of
    this bboard... In truth, some worked out fairly well, some didn't.
    It was a learning experience. It was fun playing with the output
    setting on the buxxboz and to see the effect.
    Each sphere is 4 hoops, spaced more-or-less equally. Once I welded
    them all together, I drilled a 1/2" hole through the middle and
    stuck some 1/2" rod up through the hole and welded that in place.
    The finial on top is cast iron thingie we found and welded onto the
    rod.
    The sphere is kind of flattened -- they did not nest "nicely" so the bigger
    ones had to be squished down to fit.
    Frank
    Akron,Pa
    152
    still looks pretty good. its good you had fun doing it anyway the way I look at it is you can only get better from there.
    May 2008
    Troy, MI
    273
    Nice job. Keep it up.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
