    Dec 2008
    Utah
    6
    Default Large sheet (Tin or aluminum)
    Has anyone ever seen a 4' X 8' sheet of tin? Aluminum?
    I am looking for a sheet that size for a (plasma cut) project. I am trying to find 1/8" thickness.
    Not looking for a specific retailer, just wondering if such a beast exists. THANKS
    Yeah they make 4x8 sheets of alluminum. I just bought a sheet of 1/8" a month or so ago.
    Josh
    _______________________
    Dynasty 200dx
    CoolMate 3
    Millermatic 180
    Lake of the Ozarks MO
    3,447
    Tin is a slang term. 4x8 is the standard with 5x10 and 5x12 and others as options as well as coils too.
    Aluminum at that thickness doesn't come out very nice with plasma. Thinner does a bit better. Steel is much nicer and cheaper for this and stainless is nicer as well but more costly. They also come in 4x8 too. HTH
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Dec 2008
    Utah
    6
    Thanks guys - I am using a projector to cast the ridgeline of a famous mountain range onto the piece, tracing it, then cutting the sillouhette as a wall hanging on a large (and high) surface. I have access to a CNC, but the rougher texture of free handing will be better for this application.
    Backlighting, etc. should finish it off nicely.
    Thanks again.
    Oklahoma
    641
    Quote Originally Posted by Teton123 View Post
    May be the most common size sheet you will find.
    Griff
