1x1 is waaaaaaaay too small for a trailer, don't even consider it. I've got a 3000# 5X10 trailer (Big Tex 29SA) that's all made of 2x3x3/16 angle, and it handled a 4500# cube of 8" blocks with NO flexing at all.
trailer mf'rs use angle because it's cheap and it works.
My 7000# 14' homesteader challenger (714CT) uses tube for the main frame rails, and angle for everything else. there's no discernable flex in that one either...
Results 21 to 30 of 40
Thread: 5 X 10 Trailer Questions
12-31-2008, 03:10 PM #21
Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
12-31-2008, 03:46 PM #22
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
12-31-2008, 05:18 PM #23
- Mar 2008
- Midwest
- 109
Hope I did not rain on anyones parade. After building my 14ft, it sure appeared to me the initial specs on this post were on the light side. Thats why I shared my specs. I have two more trailer plans in the mill. A dump and a follow-on 18ft enclosed. I'll bump up the main runners and tongue on the 18ft to 3/16" rectangle tube. Will probably encroach on Debar kind nature for some general tips on the dump. This is a great site, lots of ideas, lots of practical experience and willing-to-help participants. Pleased to be assoicated.
12-31-2008, 05:36 PM #24
- Sep 2006
- Abilene, Texas
- 639
I'm not sure that I understand his intentions on material to use on the trailer. He only mentioned 1" sq tubing to begin with, then mentioned 2x4" steel for the hitch. If you build the frame out of 1" sq tubing and stick 2x4" tubing onto it for the hitch you have zilch. Maybe he's figuring 2x4" tubing for the hitch and frame and 1" cross members (too light). I guess we'll never know though.
Jim
01-01-2009, 12:24 AM #25
- Feb 2008
- 9
Given the information that was provided, it's understandable why so many people feel that 1" x 1" tubing would be wholly inadequate for use in the OP's specified application. However, what these people fail to realize is, that not only is 1" x 1" tubing adequate, it is in fact more desirable to use than its conventional counterparts in certain circumstances.
For instance, if the frame were to be comprised of many diagonal/triangular elements forming a lattice (much like that of a truss bridge) it would make the whole assembly rigid, yet extremely lightweight. And this factor is indeed important, especially in light of some information that the OP inadvertently failed to mention--this trailer will be exclusively pulled by bicycle:
http://www.sfbike.org/images/resourc...r_shanghai.jpg
01-01-2009, 06:19 AM #26
I believe if the one inch sq tube was reinforced with balsa and ca it would be ok.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
01-01-2009, 06:26 AM #27
Trailer ??
Ya , Add some Balsa Wood and make it a Glider Aero Plane ??
.............. Norm :
- Weldcraft WP26FV Tig Torch setup.
- Arcair- K 4000 CAC.
- LN-25 Wire Feeder
- Miller Econo Twin AC/DC High Freq.
- Lincoln Power Mig 180C
- Spoolgun.
- Horizontal Steel Band Saw
- DeWalt Chop Saw .
01-01-2009, 08:20 AM #28
It looks as if I'm gonna have to recall all 647 trailers built at my location, all this time I thought myself and the other trailer manufacturers had something going with our designs. Boy, I guess we were wrong, 1" tubing and balsa wood was all we ever needed.
I can not even imagine how great a loss of profits I've had by not using 1" tube for the frames. Just thinking of the money I have spent on what I thought were the proper materials astounds me. I probably would'a been a gazillionaire by now.
At least it's not too late for me to reinvent the wheel, starting today I will start offering all of my trailers with a 1" square tube truss design frame as it is so much better than what we have commonly seen on the open trailer market. I'm sure all of the other manufacturers will follow this new engineering design as well.
mk10, I seriously hope your post was made in jest, the same as this reply is intendedIf necessity is the Mother of Invention, I must be the Father of Desperation!
01-01-2009, 10:27 AM #29
Miller WC-115-A
Miller Spectrum 300
SPEEDGLAS 9100XX
01-01-2009, 11:10 AM #30
He!!...............I'm as surprised as you are........did I win anything?
Yaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aLast edited by monte55; 01-01-2009 at 11:15 AM.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
