Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
Thread: Stacked Welders
    Default Stacked Welders
    I got this idea from a project that I saw on the forums. No mods to the 212 were necessary and it keeps everything together and neat.
    Mar 2007
    Oahu, Hawaii
    2,469
    NICE JOB Nice snug fit!!!!!!!
    Only thing I would add, is a strap for that MM140!
    Don't want an accident and seeing that thing topple over!!!!!!
    I'm not late...
    I'm just on Hawaiian Time
    Oct 2006
    Mpls, MN
    1,790
    Now you just need a Y for your gas hose and you'll be set.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Quote Originally Posted by Bert View Post
    I took the strap off for the picture. The only thing is that you can not open the doors but I have 11 pound rolls in there which at my hobby rate last a year. :-)
    Sep 2007
    Medford MA
    538
    what about when/if it birdsnests?
    frank
    Sep 2008
    Delta B.C.
    33
    Yup the birds nest.
    I get them when taking.
    Keep the tip clean and use the jell.
    Millermatic 135
    Nov 2006
    Lake of the Ozarks MO
    3,528
    WOW!!! Really drives home the point of marketing the MM211 doesn't it
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Mar 2007
    Deltaville, VA
    2,239
    Johngo1,
    Guess I've gotta go against most of the previous comments.
    Unless I'm missing something here, that arrangement (mig on mig) is flat out crazy. From what I'm seeing there is no lateral support for the basket/shelf (whatever) sitting on the 212. The only thing that seems to stabilize the shelf is the friction of the pads on the feet of the shelf. One little bump on one side and the whole shelf/welder come tumbling down. That cheesy little nylon strap does nothing to stabilize the shelf.
    Not only that, as has been mentioned, you've severely limited your access to your wire feed system. Major hassle.
    It's your equipment so you can treat it as you please, but if it was mine, it'd be time to go back to the drawing board.
    Just my .02
    PS As a bare minimum, I'd add support from the legs down the sides of the 212. Think of it as a saddle on a horse.
    Oct 2006
    Mpls, MN
    1,790
    One little bump and my xr control could come flopping off my cart too...
    It's not strapped or attached in any way other than gravity parking it there, but somehow it stays put.
    The airco is bolted down, but mostly because it's not designed to sit flat. Originally it was intended to be post mounted so it could rotate horizontally to aim the cable towards the weldor.
    As for serviceability - yeah, there's a design flaw with the OP's cart if you need to change rolls on the mm212 often, but I think the guy already answered for that pretty well; he's a hobbyist.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Mar 2007
    Oahu, Hawaii
    2,469
    lmao!!! That thing should say "AND ALL ACCESSORIES INCLUDED"
    or something like that Cool that you have everything right there!!!
    Do you have a picture of that cart bare??
    I'm not late...
