Results 11 to 19 of 19
Thread: Backpurging pipe HELP GUYS
12-25-2008, 11:33 PM #11
I'm not late...
I'm just on Hawaiian Time
12-25-2008, 11:34 PM #12
12-25-2008, 11:34 PM #13
12-26-2008, 05:54 AM #14
- Nov 2008
- Atl, Ga
- 375
One loaf of french bread will make about a dozen custom-fit header backpurging plugs. It's porous, non-hazardous, flame retardant, conforms to curves, leaves no glue residue, and it's dirt cheap. Another benefit is that if you have a weld where it would be difficult or impossible to remove the baffle afterward just flush the tubing with water and the bread will disintegrate and be harmlessly flushed away. Chore-Boy brand stainless scouring pads work well as dams too. Under $2 at almost any supermarket. Pads
My backpurging hose is regular inert gas line with a short piece of steel fuel line press fit onto the end. I use a Harris 356 twin regulator with two independent flowmeters (one for torch, one for purge) but some people just use a Y fitting and up their flow rate slightly to compensate for purging losses.
If you want a real backpurging dam, look at picture on the bottom left of page 40 and copy the design when you have some spare time to goof around.http://www.millerwelds.com/resources...Book_Chpt4.pdf
12-26-2008, 11:25 AM #15
- Oct 2007
- 2,949
12-26-2008, 12:01 PM #16
I have been using the aluminum foil and brake line for three decades. Nothing I have ever used is faster cheaper or simpler.
A note on KB's point about positive pressure, once the atmosphere is displaced, you only need enough pressure to counteract atmosphere. Since the argon is denser than the atmosphere you can get a way with 1 - 3 psig.
12-27-2008, 08:44 AM #17
- Dec 2007
- Oklahoma
- 641
http://www.intercononline.com/welding/mainpurg.htm
http://files.aws.org/wj/2006/12/wj200612/wj1206-38.pdf
Out of curiosity, I googled "pipe purge dams" and got 304,000 hits. Umm.
GriffLast edited by griff01; 12-27-2008 at 08:49 AM.
02-27-2013, 09:52 PM #18
- Feb 2013
- 4
mark.c
No need to purge aluminum makes no difference, I have welded pipes 100% xray without purge
02-28-2013, 06:22 AM #19
Member
- Dec 2012
- Simcoe Ontario
- 47
Foam from an old couch cushion works well or for tape they make that aluminum foil tape it won't burn only the glue gets a bit messy.
Very good idea, however!
