Results 1 to 10 of 19
    Dec 2008
    Cleveland, Oh
    2
    Default Backpurging pipe HELP GUYS
    Hey guys my name is Ryan and I am an aviation tig welder and fabricator of custom turbo kits on the side. I do A LOT of pipe welding and I REALLLLY need to find plugs I can use for the ends of my tubing to backpurge with and I do not have the time to make them and I know someone out there makes them. I searched and searched and couldnt find anything please help me out. Thx guys
    Ryan.
    P.S. the pipe im welding is 1.25/1.5/2.0" ID
    Oct 2007
    2,949
    Question SS Pipe
    Teglove2: There's 3 Forum members that might be able to help you. KB Fabrication, Turbo38t, and Fusionking all work with stainless (pretty sure). If nothing else, send them a PM if you don't hear from them soon. I'm sure there are many others, but these 3 come to my mind "right off the bat."
    Good Luck
    Dave
    "Bonne journe'e mes amis"
    Jul 2008
    East Tennessee
    615
    If I don't have the right size plug I break out the masking tape and paper .
    alabama
    751
    A plastic end cap off of the pipe that the manufacturer sends the pipe wth works well if the end to purge has no flange to interfere wth.Other options are purge paper,cardboard,foil or maskin tape.
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Jan 2006
    Eugene, Oregon
    2,428
    Quote Originally Posted by Showdog75 View Post
    That's really all you need. Argon so readily displaces atmosphere that setting up a purge is not difficult at all. In fact, You don't want any kind of airtight seal as it would negate the positive pressure that a little "leaking" will provide. Lots of times I will just use a spring clamp to attach the argon hose inside a tube and then just tape around the whole thing. Blue painters tape works very well as it leaves no residue behind. Of course, that is dependent on how close you are to the seam but aluminum foil works equally as well.
    If you really are
    Quote Originally Posted by Teglove2
    then this should be a no-brainer. If you really need to have some off the shelf products for your application and have plenty of cash, you might try a google search.
    http://www.cob-industries.com/argweld.htm
    Dynasty 350DX
    Dynasty 200DX TigRunner
    MM 350P
    MM Passport Plus
    Spectrum 375 Extreme
    08' Trailblazer 302
    Dec 2008
    Cleveland, Oh
    2
    thx for the quick replys fellas but nothing that was said can help me...the tubing gets VERY HOT and I cannot use any sort of tape I need metal plugs with holes I saw a guy on a honda forum that builds manifolds and he had a billet plug and thats what I need but in 3 sizes like stated above. Tape is also too weak and when I put the argon line in the tape the weight of the line itself tears the tape and leaves a nasty residue thats very hard to get off.
    Jun 2004
    nj
    204
    Cut two sheet metal disks (22Ga or so) a little larger than OD of tube
    Notch edge in a dozen or so places to form tabs
    Bend tabs over to fit the OD of the tube
    (you can also notch and bend to fit ID)
    Drill hole in center of one disk for hose fitting.
    Stick one over each end of the tubing (if needed, squeeze a couple of the tabs tighter to hold in place, or use a hose clamp over the tabs) and turn on the gas.
    You don't need or want a tight fit... if there isn't the ability for some venting, pressure buildup will make closing up nearly impossible. If there is too much leakage, wrap (or stuff into the ends under the caps) some kaowool to cut it down.
    Low flow rates fed from the bottom are better (less mixing while purging)
    Jan 2006
    Eugene, Oregon
    2,428
    Quote Originally Posted by enlpck View Post
    More good advice but the OP said he doesn't have the time to make anything. Anywho, commercial products like this are easy to find but you have to know what to type into a search engine.
    http://www.arc-zone.com/index.php?ma...x&cPath=10_616
    ROFLMAO, hold onto your wallet.
    Dynasty 350DX
    MM 350P
    MM Passport Plus
    08' Trailblazer 302
    Jun 2004
    nj
    204
    Of course, I SHOULD mention that pretty much all I use is aluminum foil. Slap it over the end and squeeze. Then again, I don't have the need to purge very often. A length of brake line (I think its brake line... looks like brake line and the same size) on the end on the hose bends whatever way needed to hang the hose off the work, and is also heat resistant, and the foil squeezes over this as well as a plain end.
    Mar 2006
    Queens NY
    1,547
    Lets see,
    Speed tape
    heavy duty alluminum foil (use some safety wire to secure if necessary)
    Take some scrap pipe and pound annealed aluminum over the end to make a cap
    cap a piece of scrap pipe, grind a taper in it and tap it into the hole
    Find a machine shop
    fiberglass cloth
    steel wool?
    If the hose is melting shove a piece of soft copper in it and bend the copper into a hook.
    As a Fabricator, this is really something you should make to suit your needs. If you want to buy it your certainly entitled but its something like a chef ordering out. Hope you don't take that the wrong way!
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
