I am looking for ideas for a tilting trailer to haul a dragster. The dragster itself will be 200 inch wheelbase and will be between 4 and 5 feet wide. Weight will be between 1200-1500 pounds.
I would like to use a 4 inch drop axle to keep deck height as low as posible and to keeps ramps from being too long I would like the deck to tilt without unhooking the hitch. I would also like to use a single axle and keep GVW under 3000 lbs to avoid yearly state inspections.(PA) I relize single axle and 3k weight may not be doable.
Anyone here ever build a trailer like this or have plans they could share,ideas??
Frank aka The Weekend Welder
Results 1 to 2 of 2
10-16-2011, 07:47 PM #1
Member
- Oct 2007
- Milton PA
- 39
Tilting Trailer to haul Slingshot Dragster
10-19-2011, 07:22 PM #2
i haven't built a trailer in quite a while, but i found this on google search. http://www.rhscales.com/trailerandtowingparts.pdf
I shows 3,500# 4" dropped axles in many sizes. The rest would be engineering a tilt system and latching mech. I think i would go with hydraulic to operate the tilt as drag cars have more weight in rear half, unless you plan on backing or winching it on rear first. Just a couple ideas after a couple of drinks.
