Results 1 to 10 of 16
    Aug 2006
    Raymore Missouri
    1,920
    Default Are there stronger bolts?
    Is there a stronger bolt I can use better than a grade 8? What does"AN" desigination mean?
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Jul 2007
    Lancaster, Pa
    431
    Nick, we use a Grade 9 at work. The only trouble is, the grade 9 is more brittle than the grade 8 and it will break quicker, however the grade 9 does have more holding stength.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Aug 2006
    Raymore Missouri
    1,920
    KBar........thanks for the comeback. How are they stronger? Shear load or enlongation(sp)or both............Nick
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Dec 2008
    Virginia
    4
    I always heard that "AN" meant Army-navy... which is a standardized style of hardware and fittings.
    Also I have seen and have used Grade 9 hardware. Typically its only in a clamping situation as Grade 8 works great in shear and in tension. Keep in mind the strength and hardness of the hardware vs. the hardness of the material you are bonding. What will fail first? Is that catastophic failure? In high fatigue areas you often want your hardware to have similar properties as your clamped materials. Unless the hardware is only acting as a friction causing clamping force.
    Also grade B7 has a fairly high yeild value but with more of an elastic range than that of the typical Grade 8 hardware...
    Its more in the application of the hardware than in the actual strength of the hardware. You'd be amazed at what you can put Grade 5 and 8 through if you spec it properly.
    Jan 2008
    VA
    298
    I am no ex-purt so take this with a grain of salt.
    Depends on what you are doing with it iin high stress apps. 120,000 psi is about as high as it goes for Steel bolts using ASTM ratings. That is grade 8. There are bolts that have been made from certain alloys and or are subjected to treatments that are grade 8 but have better high or low temp use.
    There ARE bolts that are higher that 120,000 psi but you might have to go out of the realm of steel.
    I was told that AN = Airframe - Navy
    Weekend wannab racer with some welders.
    turbo38t Guest
    Just browse through a McMaster-Carr catalog or Grainger catalog. There are some stronger bolts. Especially some of the alloy ones. Dave
    Quote Originally Posted by monte55 View Post
    alabama
    750
    This pretty much answers most questions. http://www.unified-eng.com/scitech/bolt/boltmarks.html
    2, XMT's 350 cc/cv
    1, BOBCAT 250
    1, TRAILBLAZER 302
    1, MILLER DVI
    1, PASSPORT PLUS
    1, DYNASTY 200 DX
    1, MAXSTAR 150 STL
    1, HOBART CHAMP
    1, HF-251 BOX
    1, S-74d
    1, S-75DXA
    2, 12-RC SUITCASES
    2, 30 A spoolguns
    Jul 2007
    Lancaster, Pa
    431
    I actually prefer the grade 8 over the grade 9 because of the shear strength, the grade 9 will snap quick with a sharp impact or sizable load against it. But because of technical & liability issues, we need to use the grade 9.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    2009 FXDC
    Feb 2005
    N.E. SD
    1,381
    FWIW, if you have trouble with bulk bin grade 8 bolts, take a trip to your local CAT dealer. They are known for quality fasteners.
    Jeff
    Oct 2007
    Cave Creek Az
    1,050
    I am curious to know what hte application is. Generally if a grade 8 bolt can't handle the stress you need either more of them or a bigger diameter bolt.
