Results 1 to 7 of 7
Thread: Exhaust jig
    Dec 2008
    Lake Jackson, Texas
    12
    Default Exhaust jig
    Does anyone have any ideas on how to build an exhaust jig for building racing exhaust?? Will go on mini sprints!!
    Thanks,
    Zeb
    Mar 2008
    Anchorage AK
    344
    How many do you plan on building?
    Makes a big difference on the design of the jig.
    If just building 1-3 I would make a jig at all.
    Jan 2009
    Cleveland, TN
    229
    1/8 in. angle is a good choice. Make your first header on the car (or at least tack it). Then, use it to make the jig. Next, take a piece of angle and use it to bolt the flange to. Off of that make a frame that you can add more pieces of angle to in some of the long straight pieces of the primary tubing. It will look crazy without a header in the jig, but they work. The size angle depends on primary size. 2 in. is a good size for most. This is a very basic description I know, but it should help.
    Dec 2005
    wisconsin
    836
    I guess I think a little different. I would fabricate the exhaust system on the engine/car, then start doing the power and tuning development on it. Lots of cutting up and changes until it works just right for the application. When everything it the way you like, then build a jig from the prototype. Just remember to let the fixture have a little "give" as to not stress the welds durring cooling. Have at it !
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Jan 2009
    Cleveland, TN
    229
    Aero, I thought about all of that, but He only asked how to make a jig. He may have a proven header design, but just wants to make some extras.
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by wrenchnride247 View Post
    I dunno a guy that has already designed and fabricated his exhaust system probably doesnt need to ask how to make a jig for it
    Miller Spot Welder
    Jan 2009
    Cleveland, TN
    229
    Well, If anything we've added some posts to his thread.
