Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Picket Twister
    May 2008
    Default Picket Twister
    Im trying to make a picket twister. I'm basically set on my idea of a gear reducer and a electric motor. My question is, does anyone know what kinda of torque it would take to twist .5 square stock? I'd be twisting lengths of 6 feet. I seen one on ebay for about 100 bucks and in has an output torque of 700 foot lbs. Any torque specs would be greatly appreciated. Thanks, Gregory
    3,648
    I built a human powered one. Its on my second floor and i can twist 16' pcs with ease. I just walk around the twister like a horse tied to a circus ride. Mine has a 3' handle and i use about 30" of it. It doesn't take much effort its more of tiring dizzy motion walking in a small circle because you have to keep pressure on the barstock until done. Someday i may add my 60:1 gearbox/motor to it if i did more with it but i can twist 10 or 15 parts 15" long in about 15 minutes...Bob
    Dec 2004
    Maryland
    132
    I made one using a old pipe threading machine. It is set on a bench I made with a adjustable tail stock,so I can make different lenght pickets. It will twist 1/2 to 3/4 solid square stock like butter. It takes less than 30 seconds to twist a 40" picket. Turn it on and count rotations.
    Lightbulb
    do a search, some one showed off theirs a wile back. great piece of work..
    watch ebay and craigslist for pipethreaders.
    the old oster machines show up quite often.
    somewhere on the interwebs i saw a scroll bender plate adapted to a pipe threader. i cant seem to find it now
    Raymore Missouri
    1,906
    Quote Originally Posted by KFCHambone View Post
    I know you ask for torque specs which I can't help. A unit that puts out 700 ft lbs must have a v-8 engine on it. I made a twister some years back that may help you. If you click on my youtube link below...you'll find a video of my electric picket twister and other stuff.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Nov 2008
    Richmond, Ky
    13
    If you have a tractor, you can make an adapter for the pto, and put the stock in a vice on the other end.
    2 -225 bobcats 1 Koehler 1 Onan
    Kalamazoo band saw
    Dewalt dry cut carbide tooth chop saw
    Hitachi grinders and drills
    Miller 210 mig
    IR air compressor Koehler engine
    Hypertherm Plasma cutter
    Aug 2008
    Phelps, NY
    70
    Quote Originally Posted by chasew27 View Post
    I would NOT do that unless you really gear down the PTO, barstock spinning at 540 or 1000 RPM would be *dangerous*
    3,648
    Quote Originally Posted by ctrhenry View Post
    My powered scroller with a 60:1 gearbox...Bob
