Results 1 to 2 of 2
    Sep 2008
    Omaha, NE
    447
    Default Diesel truck guys (need a cummins 5.9 turbo)
    Like it says, i'm looking for a Holset HX35, H1C, H1e or similar turbo taken from a dodge 5.9 cummins motor.
    The exhaust housing does not even need to be there, looking for the CHRA and compressor housing to be put in a smaller turbing housing for my 4 cyl eclipse motor. Trying to break into the 500 HP range with the motor i currently have in the machine shop and these turbos are what i want for at least getting me to 425-450 range, then i'll add the funny juice to break in the 500's
    These turbos were used on most all dodge cummins diesel motors from the mid 90's to mid 2000's model years.. on the 5.9 liter... Hopefully some of you have upgraded and sitll have the old one laying around and could use a few extra bucks for christmass
    PM me or reply here..
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
    258
    Check your private message's
