Results 1 to 10 of 17
    Dec 2008
    10
    Default Homemade BumpGate Opener/Bumber
    Hello,
    I have a 98 Ford F-150 with no grill gaurd, my issue is that a ranch that I visit has bump gates. These are gates that you must bump with your vehicle in order to go through. when you hit them they swing open and you drive through. I don't want to invest in a grill gaurd, and was thinking of building a gadget that I could attach to my truck temporarily just for this purpose. Any help is greatly appreciated....keep up the good threads!
    WY...armpit of U.S.A.
    659
    Sorry, couldn't help myself...
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Dec 2008
    10
    Good one...believe me, that's how I feel sometimes!!!
    i would just make a simple bolt under push type. i got a bit caried away with mine, but it bolts on under the bumper and threw it as well. but if ya just want to add some thing to hit a gate, maybe atach a trailor 2" recever to the front that you can slide the push bumper into when needed and pull it out for other times. you could make a winch plate also to slide in. once the recever is in place the options are wide open.
    HF sells a small bolt on reciever for like $11 i think it was.
    my son helped with the design of mine, got a little caried away.
    Raymore Missouri
    1,920
    Strap an old tire to the front..........
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Jul 2008
    Delhi, Ontario:
    1,998
    Talking nfinch86- Canadian Weldor :
    Fun4now, Man you push some stuff around with that rig on the front of
    your truck !! Looks real good, gives me something to think about ??........ Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Dec 2008
    10
    great advice everyone...thanks for the input. I think I'm going to bolt something on the frame and weld it together so it will pertrude through the bumper opening. I'll keep u guys posted. wish me luck!
    Jan 2008
    VA
    298
    Use a hitch socket and then you can easly slide in a L shaped bump bar when it is needed. Handy for moving trailers in tight spots too. `
    i forgot to mention the ease of trailer moving with the front hitch, thanks Vicegrip
    nfinch86 i have pushed a car or two with it.
    i made it out of 10 or 12 gage, so the teeth are a lot stronger than they look. used a O/A torch to bend them into shape and a little spectrum 125 to cut the skull. the back lighting is hooked into the parking lights, so when i turn on the lights at night it shows up great.
    i coated the hole thing with rubber bed liner ( similar to ryno-liner) so i have not had any trouble with scratches or rust. been on there for a few years now and still looks good as new.
    you can get spray on bed liner at wally-world, great stuff, i also lined my lawn mower trailer with it. stuff works great, for $8 a can you cant beat the protection and you can paint over it.
    JNH92 be shore to share some pic's when you Get-R-Done.
    Dec 2008
    10
    Thanks guys...you sure are full of ideas....I definately will share pics, when I get going....thanks again!
