Results 1 to 7 of 7
    22
    Default My workbench... with a bit extra
    I thought I would share my all new bench. I still need to take everything off and paint it and there are a few more details I would like to finish but It is nearly done. It is amazing how easy it is to work now that 90% of my tools are in one place.
    There are a few things you can't see in the pictures. There is a 50' hose reel hiding under the bench top that once the bench gets air to raise the airbags then powers the hose real. Behind the tool box on the right there is 2 wire reels that hold 4 1000" rolls of wire each. I drilled holes in the top of the bench and chamfered the holes so that the wire comes up threw the top of the work bench behind the vise. The pegboard was the most expensive part of the whole project ($250), not counting the tool boxes that I had traded labor for and the black one I already had. The airbag raise the bench about 2 inches to allow the bench to be moved but I need to get better casters as they don't like all the weight of the bench. I tried to keep it light with only using 2" channel for the lower frame and below the 1/4 thick top. I used 1.5" sq for the uprights and some 1/2 pipe. I built it all from scrap $100 or less.
    I also want to add a vertical brace in the centre of the pegboard to the work top to cut down on flexing. The light/air tool rack weights a lot and tends to wiggle a bit. I added some chain and turn buckles in behind the pegboard wall and it took a lot of the flex out but it still needs a bit more tweaking.
    Mar 2008
    148
    I love the airbag design............Brilliant!
    I had a friend that used four large inflatable tires to do the same thing. To put the bench on the floor, he simply let air out of the tires..............
    RoyB
    Dartmouth, MA
    http://www.rvbprecision.com
    Millermatic 185 MIG
    Miller Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    TP Blast Cabinet
    Mar 2008
    Jedburg, SC
    21
    Outstanding job! Love the airbag idea!!! Good work!!!
    Miller Suitcase 12VS
    Miller 225 Bobcat
    Miller 30A Spool Gun & Aluminum WC Box
    Lincoln SP-200 "Ezmeralda"
    Lincoln SP-100 (Sold)
    1970's Era Sears-Farm AC/220 "Invincible" (Sold)
    Parker Plasma 40
    Tig Torch "One day, one day, I must learn to use"
    Sep 2006
    Newcastle, Oklahoma
    70
    Airbag and receiver mount top shelf.
    Jul 2008
    Delhi, Ontario:
    1,950
    Thumbs up nfinch86- Canadian Weldor :
    sapper, Hi; Where in Canada are you from?? I see lots of Can. tire stuff !!
    Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
    22
    I am in Cold Lake, Alberta.
    I hate when using a vise that a bench follows you but with the bench grounded (air bags deflated) it doesn't move an inch. I got the air bags from a vehicle leveling kit that was missing pieces for $20 with lines and fittings.
    The recievers are used for when I have to work on an axle. They extend 18" Each and can be removed and used for slide out trays for things like my tube notcher to attach too.
    Jul 2008
    Delhi, Ontario:
    1,950
    Default nfinch86- Canadian Weldor :
    That's one Sweet Set-up you have there. Everything is right there for you !!
    Great Job !!...... Norm :
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
