Results 1 to 3 of 3
Thread: foot control
    Aug 2008
    4
    Default foot control
    just got a used welder it's a miller econotig. When I stop using the foot control the gas keeps runing on for a few seconds, then it goes off. the stock # 043554 and style is KH26. Is there a problem with the foot control, or is there a quick fix.
    Any help would be greatly appreciated.
    Oct 2008
    Den Haag
    22
    The gas is supposed to keep going... It's called postflow... I'm not familliar with your welder, but I suspect that there will be a setting for it buried someplace in the menues...
    If you don't postflow your argon, you will contaminate your tungsten with oxygen from the air when it's hot from welding.
    Al...
    Aug 2008
    4
    thank for the help
