Throw 'em all in a cement mixer.
Add a couple gallons of water, some of that green cleaner and a shovel or two
of gravel.
Drink beer.
Check progress after each beer or two.
Results 11 to 20 of 20
Thread: Nuts and Bolts
11-30-2008, 04:46 AM #11
- Nov 2005
- 130
11-30-2008, 10:10 AM #12
11-30-2008, 10:11 AM #13
11-30-2008, 10:54 AM #14
- Jun 2008
- 7
get a 5 gallon bucket of hydrochloric acid to dunk them in. the acid will dissolve any non-metal it touches so be careful of getting it on yourself, but overnight in that stuff will eat away paint, grease, grime, soft chrome, silicone, all kinds of plastics and even wood if its attached. for small parts i have a small bucket with holes in the bottom to hold them and big parts i just dangle in attached to baling wire. just make sure you rinse with water thoroughly after you pull them out to neutralize the acid, and be careful not to get any on anything non metal you want to keep...including yourself
11-30-2008, 11:16 AM #15
11-30-2008, 11:41 AM #16
11-30-2008, 12:52 PM #17
- Jun 2008
- 7
it doesnt give off too much in the way of fumes but its definitely not something id leave the lid off of forever or breathe too deeply. as far as disposal id look into industrial waste disposal companies. there's companies that specialize in cleaning the sludge out of factory floor drains, oil-water separation systems, and solvent tanks that can deal with it. personally i think its the way to go if youre into chemical cleaning as it lasts a lot longer than most any solvent you can buy before it becomes nasty and a 5 gallon bucket will hold most any parts you might need done.
11-30-2008, 01:03 PM #18
- Nov 2008
- Western Washington State
- 2
Here's another way if you have the time to cobble it together. http://www.fordmuscle.com/forums/tec...ctrolysis.html
11-30-2008, 04:04 PM #19
- Sep 2005
- 4,246
Does all this sound worth the effort? Would likely cost about half as much to buy what you needed new.
12-01-2008, 04:30 PM #20
Shell reloaders use a vibrator cleaning system and they are available at I think grizzley.
http://www.grizzly.com/catalog/2008/Main/627
this could be a good start.
Peace,
Paul
