Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Nuts and Bolts
    Nov 2005
    130
    Throw 'em all in a cement mixer.
    Add a couple gallons of water, some of that green cleaner and a shovel or two
    of gravel.
    Drink beer.
    Check progress after each beer or two.
    Dec 2006
    Traer, IA
    317
    Quote Originally Posted by Bodybagger View Post
    Use this machine with this abrasive media in it.
    It works wonders on screws and bolts. Smoothly cleans oxidized metal. Only problems are that it doesn't really clean the internal threads and it won't clean grease. If they have dried grease, wash them in kerosene first.
    Really cleans external threads good.
    I suppose if you were really brave, you could use this media along with quart of kerosene, but that sounds like begging for a fire.
    Thanks for the info - I'll try one of those out.
    Dec 2006
    Traer, IA
    317
    Quote Originally Posted by Chuck U&R View Post
    of gravel.
    Drink beer.
    I must say I like the way you think
  4. #14
    Jun 2008
    8
    get a 5 gallon bucket of hydrochloric acid to dunk them in. the acid will dissolve any non-metal it touches so be careful of getting it on yourself, but overnight in that stuff will eat away paint, grease, grime, soft chrome, silicone, all kinds of plastics and even wood if its attached. for small parts i have a small bucket with holes in the bottom to hold them and big parts i just dangle in attached to baling wire. just make sure you rinse with water thoroughly after you pull them out to neutralize the acid, and be careful not to get any on anything non metal you want to keep...including yourself
  5. #15
    Dec 2006
    Traer, IA
    317
    Quote Originally Posted by CWB View Post
    Does that give off any harmfull fumes? Also, how is a guy suppose to dispose of the used acid? Thanks for the reply!
  6. #16
    Los Angeles
    2,914
    of gravel.
    Drink beer.
    Progress of the Nuts and Bolts or progress of inebriation
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
  7. #17
    Jun 2008
    8
    it doesnt give off too much in the way of fumes but its definitely not something id leave the lid off of forever or breathe too deeply. as far as disposal id look into industrial waste disposal companies. there's companies that specialize in cleaning the sludge out of factory floor drains, oil-water separation systems, and solvent tanks that can deal with it. personally i think its the way to go if youre into chemical cleaning as it lasts a lot longer than most any solvent you can buy before it becomes nasty and a 5 gallon bucket will hold most any parts you might need done.
  8. #18
    Nov 2008
    Western Washington State
    2
    Here's another way if you have the time to cobble it together. http://www.fordmuscle.com/forums/tec...ctrolysis.html
  9. #19
    4,435
    Does all this sound worth the effort? Would likely cost about half as much to buy what you needed new.
  10. #20
    Evansville, IN
    2,348
    Shell reloaders use a vibrator cleaning system and they are available at I think grizzley.
    http://www.grizzly.com/catalog/2008/Main/627
    this could be a good start.
    Peace,
    Paul
