Results 1 to 7 of 7
    Default what grit for sharpening tungsten??
    ok so i decided the best solution for me is going to be a diamond 6" wheel for my grinder to do my sharpening. price per function it seems the best option. so what grit would be the best option?? i was thinking of maybe getting 2 wheels one for quick clean up and one for a nice finish. but may need to stick to just one for $$ reasons.
    so if you were getting 2 disks what grit for quick clean and what for finish ?
    if you could only have one what grit would it be??
    i found a guy on e-pay with decent prices on 1"X6" disks, purity good on 8"ers also but i only have 6" grinders, so its 6"X1" for me.
    i will be only using 2% lanthanated for my TA-185 (inverter) so dust is not a huge health issue with proper grinding precautions.
    the sharpy would be my first choice but its just out of my $ range, i'm having enough trouble justifying keeping the TIG so huge expenses right now just are not going to happen. maybe later if i ever get it to make some $$
    so what do you think for disk grits??
    2 disk option???
    1 disk option ??
    thanks for the help.
    Apr 2007
    Ventura, California
    102
    Default True grit
    For 2 disks, I vote 60 grit for clean-up and 240 for finish.
    For 1 disk, I vote 80 grit. (Then save up for the 240 grit. )
    Even if the 80 grit is the only disk you have, the finish will be usable. The grinding wheel at the school shop is probably 50 grit, and will do in a pinch. I've seen guys use the belt sander if the grinder is being used. (Not a recommended practice since there no way of knowing what metal has been sanded on it. Contamination is not the TIG welders friend.)
    As you have said, the direction of the grind (along the length of the electrode) is important.
    DFW area
    180
    Save a buck where ya can.......
    What I've done is put a TIG electrode in the drill press, then shape the point with a new/dedicated wheel on my angle grinder. Then rub it with a new spot of 220 wet or dry sand paper to polish it. Get it out of the press and clean the point with a shot of carberator cleaner on a paper towel.
    I may not be smart enough to know how bad I'm screwing up,
    but that seems to work OK for me.
    "Gone are the days of wooden ships, and Iron men.
    I doubt we'll see either of their likes again".
    Circa 1920.
    Author:
    Unknown US Coast Guard unit Commander.
    Apr 2007
    Texas
    100
    Default Hi
    Hey Winger Ed,
    Check out this link for some info that may help.
    Download there free booklet on How-To.
    http://www.diamondground.com/
    Hope this helps too.
    r90s
    Oahu, Hawaii
    2,469
    r90s,
    THANKS A LOT!!! I downloaded it, and will print it out when I get more black ink tomorrow
    I'm not late...
    I'm just on Hawaiian Time
    Oahu, Hawaii
    2,469
    very!!!...cool smiley!!!!!!!!!!
    I'm not late...
    Apr 2007
    Texas
    100
    Default Glad to...
    No problem, Bert.
    were out of posting sync because I tried to change "Glad Too" title to "Glad to" title.......It can't be done........I had to delete and re-post....and with my slow typing.....well!
    But then, I guess I am "Glad Too".
