Results 1 to 10 of 20
    Nov 2008
    Illinois
    3
    Default Welding spring steel
    Is it possible under agriculture conditions. I welded a shank on an applicator the other day, the guys at work razzed me about it of course, but I would assume there must be a way to weld it and prevent it from breaking? If not , will it break at the weld , around the weld, or somewhere else? The steel is about one inch thick, 2 inches wide, and about 3 feet long with a curve in it. It's used for applying anhydrous ammonia, and typically runs in the ground 7 to 12 inches at 6 mph. I veed out the break and made 5 passes with a 6011 on ac. on both sides. Any help would be great, as I would love to prove the guys wrong just this one time! It is , I assume some type of carbon steel?
    Jun 2006
    Maine
    732
    I'm curious to the answer, because I've never managed to successfully weld spring steel. They've always re-broken in the HAZ just beyond the weld... tried it with 7018 and 6010 (the mild rods I commonly have on hand), even tried torch annealing the weld with no success.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Oct 2005
    Central Florida
    193
    Not knowing what an applicator shank is I had to google it... The one I found looks like a piece of flat bar curved in an S-shape with a chisel-looking attachment on the end that goes in the ground.
    A carbon "spring" steel probably contains .70 - .90 percent carbon like AISI 1070 - 1090 steel. That much carbon makes it sensitive to hydrogen embrittlement as well as formation of brittle microstructures such as untempered martensite in the HAZ. Just joining 1070 steel for a static application would require high preheat, a low hydrogen process with a matching strength filler metal, and post weld stress relief.
    Springs are highly stressed engineered components. The steel is typically through-hardened by heat treatment and the springs are often shot-peened to improve fatigue life. Both of these effects are reduced near the weld by the heat of welding. If a spring broke then it broke at a high stress location. A weld can never match the fatigue strength of un-welded base metal, and a weld is not going to last very long at a location with a high cyclical stress range.
    I'd be interested in hearing success stories, but my opinion is that springs aren't good candidates for weld repair. Try it if you must and if a second failure won't hurt anybody, but order a new part first...
    Bill
    "The more I learn about welding the more I find there is to learn..."
    Lake of the Ozarks MO
    3,596
    1090 is what razor blades are made of.
    A spring like that would fall more into the 1050-1060 range I believe if it was old school enuff to be a 10 anything.
    Mixed results would be what you would get. The first and main question is what broke it??
    I would say a "spring guy" could do it for sure. Welded, hammered, properly annealed and reground. Prolly cheaper to get a new sping that way.
    Could you add a leaf to it?
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    258
    The applicator shanks used in our area are not spring steel. We just pre heat and weld with 7018. They hold fine until they hit rock with them.
    3,596
    So it's sorta like a ripper tooth??
    Miller WC-115-A
    Miller Spectrum 300
    Jul 2008
    Delhi, Ontario:
    1,998
    Thumbs up nfinch86- Canadian Weldor :
    HI, I agree with Finney, as I do a lot farm repairs. Preheat at least 3" each side of the break, and weld with 7018!!..... Norm : PS. bBe sure to bevel it out, tack it up real good, weld one side, then Grind the backside back to the first weld. then weld the second side so as to have a weld all the way through!!!! Good Luck !!!..... Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    I kinda had a chuckle at your previous post when you mentioned adding a leaf to it, but I know not everyone has a farming background. That's part of the reason I visit sites like this, to learn about new things.
    Here is a picture of one type of cultivator shank assembly that I found on the web.
    The part he welded up is the curved piece, the spring assembly on top is called the "trip", it is supposed to allow the shank to flip up and over large immobile objects such as rocks. As with anything in life it doesn't always work as planned!!!
    at home:
    2007 302 Trailblazer with the Robin SOLD
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Feb 2008
    897
    6011 will leave a brittle weld in this stuff. Use DRY 7018 rods. Maintain a few hundred degrees preheat.
    What I wonder is how in the heck you found the broken piece!
    I've done that song and dance of trying to find broken implement parts or dozer teeth in the middle of nowhere and it's a real crap shoot.
    May 2008
    Belle Plaine Iowa
    270
    These applicator teeth arent real crowded on the toolbar. Its easy to find them by just going backwards down the same row in the field. Ive had farmers that were "too busy" to go look for the lost parts thinking they would find them the next trip through the field. Sure nuff! Id be out there replacing a tractor tire while they were cultivating...Still too busy! Now in the fall harvest when theyre "really busy" they call me out to replace the destroyed combine tire. This is one reason I dont work on tire any more.
    Miller AC/DC Thunderbolt 225
    Miller 180 w/Autoset
    Old cutting torch on LPG
