This is a similar post to the one on the Hobart Weld Talk Message Board because I wanted to share this with those that aren't members of both sites.
I volunteered to do all of the repair welding for the three day Robot First Regional here in Michigan at Wayne State University. The Dynasty 200 DX TIG welder was ideal because the robots are mostly made of light gage aluminum. I needed a light weight portable welding stand that I could use in a trailer located just outside of the gymnasium where the main event was held. My solution was to make a new top for my roller support for my chop saw. It worked great and it doesn't take up much room when it isn't required. It also works as a table extension at home for long narrow parts that don't fit on my regular table.
More information regarding Robot First:
http://www.usfirst.org/?gclid=CJTNgZ...FQpzHgodni2p-A
Results 1 to 10 of 17
Thread: Portable Welding Stand
11-21-2008, 08:14 PM #1
- May 2008
- Troy, MI
- 273
Miller Thunderbolt
Smith Oxyacetylene Torch
Miller Dynasty 200DX
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
11-21-2008, 10:33 PM #2
- Sep 2006
- 42
very nice!
great idea. It would be quite cost effective as well.
11-22-2008, 06:30 AM #3
- May 2008
- Fredericton, NB Canada
- 124
As a newbie welder with a somewhat limited space garage this really caught my eye.
Your stands look to be identical to the ones I have in my woodworking shop and they are the worst pieces of s*** that I ever bought - no matter how hard I reef on the red handle, the roller and stem manage to gently slide back down into the receiver tube, and it usually happens just micro seconds before I make a cut. I have been tempted to toss them on several occasions but when I got into welding as a hobby I thought to myself "I'll teach those things now". I have not yet really looked it over to see how I can correct the looseness with a good session at the stick welder though.
Did you do anything special to yours to prevent them from creeping down, or maybe I just got a couple of chinese lemons (I'm repeating myself with that phrase I know.....)
Cheers and thanks for the great project idea,
Lewis
11-22-2008, 09:21 AM #4
- Sep 2006
- 42
well you could just drill a hole and put in a pin at the working height. Hang the pin on a chain so you don't loose it.
11-22-2008, 12:38 PM #5
- May 2008
- 124
11-22-2008, 01:27 PM #6
Very cool portable unit, I like it.
I have one of those stands for woodworking and have used it while welding, I must be lucky, I've not had any problems with mine moving after I've set it.
But, I usually set it up run the table saw for a few cuts and put it away...
Miller 140 w A/S
HF 90 Amp Flux Core
Dewalt Chop Saw
Smith O/A Torch
Ryobi, HF grinders
Harley Electra Glide Classic
11-22-2008, 03:35 PM #7
nfinch86-Canadian Weldor :
Could you C-Clamp it???..... Norm :
- Arcair- K 4000 CAC.
- LN-25 Wire Feeder
- Lincoln Power Mig 180C
- Spoolgun.
- Horizontal Steel Band Saw
- DeWalt Chop Saw .
11-22-2008, 05:05 PM #8
Lewis:
I'm guessing that the end of the locking screw is rounded off. If the locking screw is 3/8", use a 5/16" drill and drill the end of the locking screw. This will make it look, and act, like a set-screw. You could also add a second lock to the other side to double your clamping power.Last edited by Craig in Denver; 11-22-2008 at 05:07 PM.
RETIRED desk jockey.
Miller Syncrowave 250.
11-22-2008, 06:20 PM #9
- May 2008
- 124
11-22-2008, 09:04 PM #10
- May 2008
- 124
Craig - I took a look at the stand - the screw does not directly bear down on the sliding post but on some in between leaf of metal. Could cause the same problems as you mentioned with the smooth ended screw though. I couldn't see how to take the thing apart but will take another crack at it tomorrow. Another option might be just to extend the lever arm of the tightening toggle and get more force on the thing.
sorry to hijack this thread
