Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Engine Dyno
    Baldwin, NY
    275
    Quote Originally Posted by 190MPH View Post
    I'm talking about strictly an engine dyno and associated room,etc. I know that 30-35 HP gains me about .08-.10 on the track.
    Well yeah, with ventilation, soundproofing, etc, all in sure $100k sounds right...
    Whatcha driving, btw?
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    NHRA Comp Elim C/D, 6.87 @ 195 best. 340" chevy/buick with split dominators on gas, just shy of 900 HP on the pump.
    Baldwin, NY
    275
    Nice, **** im slow Im only in the 10's.... Whats it weigh?
  4. #14
    Gotta be 1530 minimum(class is 4.5 lbs/c.i., wedge head motors only), usually cross the scales @ 1540 with me in it.
  5. #15
    Nov 2006
    Lake of the Ozarks MO
    3,548
    Quote Originally Posted by Badd00SS View Post
    Incorrect, it's a 2,000 hp, 225 mph capable unit. Mustang 1100 SE
    "Home :: Dyno Services/Tuning
    Dyno tuning is available with our in house Mustang 1100 SE dynamometer. Our unit is rated up to 2000 hp and 225 mph. The eddy current unit simulates real world loads found on the street or at the track. Not only can our dyno be used for tuning but also driveability and diagnostic testing, 0-60mph testing, and mile drag strip passes.
    Dyno Services Pricing:
    Power Pulls (2) with A/F monitoring $70
    Power Pulls (3) with A/F monitoring $90
    Pass (2) with A/F Monitoring $85
    Pass (3) with A/F Monitoring $105
    0 - 60 MPH (2) $45
    0 - 60 MPH (3) $60
    Hour Rental with operator $200
    Are you and a group of friends interested in getting together to see who will drop the biggest number on the dyno? Contact us for our discounted pricing on group (minimum 10 cars) dyno days and see who can drop the bomb.
    Tuning Pricing:
    Basic Bolt on Tune: $350"
    Very interesting...where are you located?
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
  6. #16
    Baldwin, NY
    275
    My friends shop is in Deer Park, NY but he is moving soon further out east on the island....
  7. #17
    Jun 2008
    8
    i look at engine dynos as being basically worthless to anybody but professional engine builders like Vic Edelbrock. i prefer to know what my car makes at the wheels because that gives a more accurate idea of what power is being transferred to the ground. realistically the only reason that i see to have an engine dyno is if youre building serious competition or experimental engines that have a good chance of exploding and you dont want them doing so inside your car. thats also the reason most large companies that have these isolated "test cells" also have techs monitor the engines through several layers of bullet resistant glass and cover major portions of the engines with scatter shields. generally these "test cells" are also humidity and temperature controlled with no need for any sort of "correction factor." the SAE (not ASE) has a standard humidity and temperature that dictate how automakers test engines and report their hp. personally i've been tempted to bid on a few chassis dynos ive seen around but not sure i can justify the expense yet...lil too much for a toy. for now i'll stick to paying $100 anytime i get curious
  8. #18
    The money you spend for a day on an engine dyno is well spent if you are serious about racing. It will wind up costing you exponentially more to try and find a baseline tuneup trying to test at the track. Not only that, but a serious race engine needs time to seat the rings, which on the track takes several runs in a motor like mine. A day on the dyno does this also, so the good bean oil can be put in for the 1st run down the track. You'd be surprised how much HP that is worth. As far as the exploding an engine on the dyno instead of in your car, believe it or not, the dyno is easier on the motor than true race conditions. I guess it's all a matter of your situation and how serious you are, no disrespect intended to anyone into any type of motorsports.
