As long as the pin goes in smoothly & is not sloppy it will not have extra stress. You are correct in thinking that if it went to someone that does this type of work all the time both ears would be cut off & new ones installed then line bored. I just assumed that he didn't have that type of equipment so the next best thing would be 2" diameter wheels on a grinder or a good die grinder. That would be the very time consuming part of the job that I mentioned.
Results 11 to 13 of 13
Thread: Need Fast Help!
07-15-2007, 05:12 AM #11
07-17-2007, 07:19 PM #12
Did you get it done?
07-22-2007, 10:30 AM #13
- Jan 2007
- 53
got it done
got er done i welded the ear back on with 7018, i did not have the type of flux core wire on hand that you guys recommended, of course on Saturday afternoon all the lws are closed. I left the pin in while i welded, let it cool down overnite with pin in ,next mourning the pin slid rite out. MISSION ACCOMPLISHED
Still waiting on the bucket fingers that need to be replaced, backorder from supplier. Thanks for the info guys,
/22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
33x33 enclosed shop when its to cold or windy outside
miller 210
miller 875 plasma
victor oxy/accet
unihydro 45ton ironworker
miller 180 tig
ole lincoln ac/dc buzzbox
milwaukee power tools
and everything in between
2007 trailblazer 302
Bailiegh 210 miter saw-2008
Beer Fridge
6000# cat forklift
36" port-a-cool fan
Dake G-75 Belt grinder
3035 Spoolgun
