Results 1 to 10 of 13
Thread: Need Fast Help!
    Default Need Fast Help!
    Customer called this mourning help ,help, Broke eye off trackhoe bucket , got there sure thing ripped one eye off that holds the 3-1/2" pin that goes through the backhoe boom, bent the other eye need to fix asap. My question is when i weld the new bracket back on should i lo-hydro rod - flux core- or plain wire? Also he informed me he needs the tooth keepers replaced on another bucket, same situation or are they welded on and maybe hradsurfaced on top of the welds?
    /22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
    33x33 enclosed shop when its to cold or windy outside
    miller 210
    miller 875 plasma
    victor oxy/accet
    unihydro 45ton ironworker
    miller 180 tig
    ole lincoln ac/dc buzzbox
    milwaukee power tools
    and everything in between
    2007 trailblazer 302
    Bailiegh 210 miter saw-2008
    Beer Fridge
    6000# cat forklift
    36" port-a-cool fan
    Dake G-75 Belt grinder
    3035 Spoolgun
    Oct 2006
    British Columbia
    500
    Cool Need Fast Help!
    Well flux core is good. Put the pin back in and tack the ears back on brace the ears so they wont pull in all kinds of directions then take the pin out and weld alternate passes from one side to another.
    The tooth keepers replaced on another bucket, I believe those can be pinned ,bolted or welded on then you would hard surface the top and bottom of the tooth.
    Default arc gouging?
    Thanks darmik for Quick response, i was leaning toward flux core in such it would be faster, one more question . How much air supply do you need to run an arc gouger? ran one 30 years ago but this sometimers disease is getting the best of me. Arcair makes a medium duty torch which i think i can run off my trailblazer to gouge these keeper teeth off but i do not know if the ole craftsman compressor will supply enough air?
    miller 210
    miller 875 plasma
    victor oxy/accet
    miller 180 tig
    Beer Fridge
    6000# cat forklift
    36" port-a-cool fan
    3035 Spoolgun
    Jun 2006
    Calgary, Alberta
    377
    Make sure you do a little pre heating to weld the ear back on, say heat it until your spit boils off (: It's probably T-1, and FCAW will work fine with most wires. Also like Darmik said make sure the pin is inplace, and also, cross brace the bucket ears with some heavy tubing or flat bar. Typically use the same for the adapters. If you have a fire blanket wrap the parts and let them cool slowly, though this is not absolutely nescessary.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    Jul 2007
    Indiana
    22
    Quote Originally Posted by shade tree welder View Post
    you need abobe PDF reader, but free downloads are everywhere.
    http://www.thermadyne.com/twecoarcai...89_250_008.pdf
    see page 2-12
    Martin
    Welding Technician
    AWS Certified Welding Inspector
    AWS Certified Welding Educator
    ASNT ACCP Level II VT/GI/D
    www.linkedin.com/pub/martin-cramer/20/b36/940/
    Jan 2007
    Noth Dakota
    505
    Arcair recommends 90 psi minimum.
    Aug 2006
    near rochester NY
    9,881
    Steve, i think he means how much flow??CFPM to know if his compressor will keep up or not.
    Jul 2007
    Indiana
    22
    Default Here's the recommendations from the Tweco arcair literature that I posted priviously
    Type of Torch psi Kpa cfm L/min. hp kW hp kW gal lit.
    Light Duty (2) 40 280 8 227 .5 0.4 1.5 1.1 60 227
    General Duty (2) 80 550 25 708 5 3.7 7.5 5.6 80 303
    Multipurpose (3) 80 550 33 934 7.5 5.6 10 7.5 80 303
    Automatic (4) 60 414 46 1303 15 11.2 80 303
    Martin
    Welding Technician
    northern NJ
    1,825
    7018 would be good. When you say flux core I'm assuming you mean gasless wire? There are many types of wire & some are no good for this application. For example Lincoln NR-211 is only recommended for welding up to 1/2" thick steel. E71T-GS wire is for single pass only. Neither one would be good for this. I would recomend Lincoln NR-212 1/16" diameter wire which is a self shielded wire. Lincoln 71m or ESAB 7100 ultra which are dual-shield wires (need gas). Line up & tack on the machine with the pin, then remove & brace. Put pin back in & weld 1 pass on each side alternating until you get the size weld you want. The bent ear will require lots of heat to straighten & might be oblonged/egg shaped when bent back. You can weld up the bore & then grind it back to shape. Very time consuming to do a nice job. To weld on shanks (tooth keepers?), cut of old & weld on new with 7018 or a good wire like I recomended above. I never hard face them. Air-arc run about 90 psi. Even a small compressor will work but you might have to gouge some & then let the compressor catch up before you gouge some more.
    MM250
    RCCS-14
    Aug 2006
    Oklahoma City, Oklahoma
    304
    Ok, I'm stepping way out of my experience level here, but wouldn't you need to do some sort of line boring on the repaired eyes to make sure everything was true so as to not induce extra stresses and accelerated wear on the pivot points? Just curious. SSS
