Customer called this mourning help ,help, Broke eye off trackhoe bucket , got there sure thing ripped one eye off that holds the 3-1/2" pin that goes through the backhoe boom, bent the other eye need to fix asap. My question is when i weld the new bracket back on should i lo-hydro rod - flux core- or plain wire? Also he informed me he needs the tooth keepers replaced on another bucket, same situation or are they welded on and maybe hradsurfaced on top of the welds?![]()
Results 1 to 10 of 13
Thread: Need Fast Help!
07-13-2007, 06:42 PM #1
- Jan 2007
- 53
Need Fast Help!
/22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
33x33 enclosed shop when its to cold or windy outside
miller 210
miller 875 plasma
victor oxy/accet
unihydro 45ton ironworker
miller 180 tig
ole lincoln ac/dc buzzbox
milwaukee power tools
and everything in between
2007 trailblazer 302
Bailiegh 210 miter saw-2008
Beer Fridge
6000# cat forklift
36" port-a-cool fan
Dake G-75 Belt grinder
3035 Spoolgun
07-13-2007, 06:56 PM #2
Need Fast Help!
Well flux core is good. Put the pin back in and tack the ears back on brace the ears so they wont pull in all kinds of directions then take the pin out and weld alternate passes from one side to another.
The tooth keepers replaced on another bucket, I believe those can be pinned ,bolted or welded on then you would hard surface the top and bottom of the tooth.
07-13-2007, 07:22 PM #3
- Jan 2007
- 53
arc gouging?
Thanks darmik for Quick response, i was leaning toward flux core in such it would be faster, one more question . How much air supply do you need to run an arc gouger? ran one 30 years ago but this sometimers disease is getting the best of me. Arcair makes a medium duty torch which i think i can run off my trailblazer to gouge these keeper teeth off but i do not know if the ole craftsman compressor will supply enough air?
miller 210
miller 875 plasma
victor oxy/accet
miller 180 tig
Beer Fridge
6000# cat forklift
36" port-a-cool fan
3035 Spoolgun
07-13-2007, 09:04 PM #4
Make sure you do a little pre heating to weld the ear back on, say heat it until your spit boils off (: It's probably T-1, and FCAW will work fine with most wires. Also like Darmik said make sure the pin is inplace, and also, cross brace the bucket ears with some heavy tubing or flat bar. Typically use the same for the adapters. If you have a fire blanket wrap the parts and let them cool slowly, though this is not absolutely nescessary.
Jonny
Dynasty 300DX
Esab PCM 1000
07-14-2007, 06:22 AM #5
you need abobe PDF reader, but free downloads are everywhere.
http://www.thermadyne.com/twecoarcai...89_250_008.pdf
see page 2-12Martin
Welding Technician
AWS Certified Welding Inspector
AWS Certified Welding Educator
ASNT ACCP Level II VT/GI/D
07-14-2007, 06:23 AM #6
Arcair recommends 90 psi minimum.
07-14-2007, 06:58 AM #7
Steve, i think he means how much flow??CFPM to know if his compressor will keep up or not.
james@newyorkmetalart.com
07-14-2007, 07:27 AM #8
Here's the recommendations from the Tweco arcair literature that I posted priviously
Type of Torch psi Kpa cfm L/min. hp kW hp kW gal lit.
Light Duty (2) 40 280 8 227 .5 0.4 1.5 1.1 60 227
General Duty (2) 80 550 25 708 5 3.7 7.5 5.6 80 303
Multipurpose (3) 80 550 33 934 7.5 5.6 10 7.5 80 303
Automatic (4) 60 414 46 1303 15 11.2 80 303Martin
Welding Technician
07-14-2007, 06:58 PM #9
7018 would be good. When you say flux core I'm assuming you mean gasless wire? There are many types of wire & some are no good for this application. For example Lincoln NR-211 is only recommended for welding up to 1/2" thick steel. E71T-GS wire is for single pass only. Neither one would be good for this. I would recomend Lincoln NR-212 1/16" diameter wire which is a self shielded wire. Lincoln 71m or ESAB 7100 ultra which are dual-shield wires (need gas). Line up & tack on the machine with the pin, then remove & brace. Put pin back in & weld 1 pass on each side alternating until you get the size weld you want. The bent ear will require lots of heat to straighten & might be oblonged/egg shaped when bent back. You can weld up the bore & then grind it back to shape. Very time consuming to do a nice job. To weld on shanks (tooth keepers?), cut of old & weld on new with 7018 or a good wire like I recomended above. I never hard face them. Air-arc run about 90 psi. Even a small compressor will work but you might have to gouge some & then let the compressor catch up before you gouge some more.
07-15-2007, 12:08 AM #10
Ok, I'm stepping way out of my experience level here, but wouldn't you need to do some sort of line boring on the repaired eyes to make sure everything was true so as to not induce extra stresses and accelerated wear on the pivot points? Just curious. SSS
