Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Nov 2008
    12
    Thanks, that clear it up.
    daye
    Oct 2007
    2,949
    Thumbs up Plasma Cutting Aluminum
    I've also found that nitrogen (dry air) makes for a better cut on aluminum
    S.W. Pennsylvania
    2,249
    I seem to remember a thread a while back ago about aluminum aircraft panels. If I remember right, they are not to be cut with plasma due to the effect of the HAZ.
    To all who contribute to this board.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
  4. #14
    Jan 2008
    VA
    298
    A good dessicant air dryer just prior to the Plasma improves the cuts and the tip life as well. The media can be recharged many times by heating to 250 deg untill it changes back to the "dry" color.
    Weekend wannab racer with some welders.
  5. #15
    Feb 2008
    Guam
    177
    Default Door skin
    I cut some small patterns out of door skin (1\16) it was damp from being outside,but it worked well enough for what I neded at the time.
