Results 1 to 10 of 15
    Raymore Missouri
    1,906
    Default Cast Iron & plasma
    Can you plasma cut cast iron or if not .........what? I have to cut the center out of a cast iron floor drain cover.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    4,246
    Yes, plasma cuts cast well.
    Nov 2008
    New Hampshire
    29
    I second that... plasma works well on most anything that conducts electricity
    Kelly
    Trailblazer 301D
    2 XMT 304's
    Dynasty 300 Tigrunner
    Spectrum 2050
    XR with ALUMA-PRO
    12RC suitcase
    Millermatic 251
    60a feeder
    Ellis 1600
    Bridgeport
    16" southbend
    Too many Hand tools...
    Raymore Missouri
    1,906
    Thanks guys...........Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Raymore Missouri
    1,906
    Quote Originally Posted by pyro2 View Post
    I thought I heard one could not plasma cut aluminum.....?????
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Jul 2008
    Delhi, Ontario:
    1,950
    Default nfinch86- Canadian Weldor:
    NOT TRUE!!....... Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
    Chicago-ish
    282
    It cuts aluminum great. It's just that raw plasma-cut edges aren't ideal for welding because of the oxides, and the HAZ.
    Nov 2008
    12
    Quote Originally Posted by spotsineyes View Post
    Could you explain more. I'am thinking about buy a plasma cutter and don't know a alot about them. what do you mean buy "HAZ" I understand the oxides part. I think. This can be cleaned up by a stainless wire brush then welded. thanks daye
    Chicago-ish
    282
    Heat Affected Zone. I don't remember what was said in other posts as to how it affects the weld, now that I think about it.
    Jun 2004
    nj
    204
    HAZ: heat affected zone. The properties of the material are changed in the HAZ in a variety of ways, and depend on the material. Examples include loss of heat treatment, growth of grain structure, loss of toughness or strength (due to the annealing of cold worked material), microscopic cracks....
    For aluminum, loss of heat treatment from heat treated alloys is probably the major issue, same as when laying on weld, but grain growth and cracking can also be an issue with some alloys.
    Clean up before welding with a file, carbide burr, or other mechanical cutting method to remove oxide. Just brushing, or improper grinding, can drive bits of the oxide into the metal surface. The weld heat will USUALLY do more to the mechanical and chemical properties than the heat from plasma cutting.
