Can you plasma cut cast iron or if not .........what? I have to cut the center out of a cast iron floor drain cover.
Results 1 to 10 of 15
Thread: Cast Iron & plasma
11-18-2008, 04:08 PM #1
Cast Iron & plasma
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
11-18-2008, 04:10 PM #2
- Sep 2005
- 4,247
Yes, plasma cuts cast well.
11-18-2008, 04:34 PM #3
I second that... plasma works well on most anything that conducts electricity
Kelly
Trailblazer 301D
2 XMT 304's
Dynasty 300 Tigrunner
Spectrum 2050
XR with ALUMA-PRO
12RC suitcase
Millermatic 251
60a feeder
Ellis 1600
Bridgeport
16" southbend
Too many Hand tools...
11-18-2008, 05:10 PM #4
Thanks guys...........Nick
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
11-18-2008, 05:12 PM #5
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
11-18-2008, 05:45 PM #6
nfinch86- Canadian Weldor:
- Weldcraft WP26FV Tig Torch setup.
- Arcair- K 4000 CAC.
- LN-25 Wire Feeder
- Miller Econo Twin AC/DC High Freq.
- Lincoln Power Mig 180C
- Spoolgun.
- Horizontal Steel Band Saw
- DeWalt Chop Saw .
11-18-2008, 05:47 PM #7
- Mar 2006
- Chicago-ish
- 282
It cuts aluminum great. It's just that raw plasma-cut edges aren't ideal for welding because of the oxides, and the HAZ.
11-18-2008, 06:34 PM #8
- Nov 2008
- 12
11-18-2008, 06:43 PM #9
- Mar 2006
- Chicago-ish
- 282
Heat Affected Zone. I don't remember what was said in other posts as to how it affects the weld, now that I think about it.
11-18-2008, 06:51 PM #10
- Jun 2004
- nj
- 204
HAZ: heat affected zone. The properties of the material are changed in the HAZ in a variety of ways, and depend on the material. Examples include loss of heat treatment, growth of grain structure, loss of toughness or strength (due to the annealing of cold worked material), microscopic cracks....
For aluminum, loss of heat treatment from heat treated alloys is probably the major issue, same as when laying on weld, but grain growth and cracking can also be an issue with some alloys.
Clean up before welding with a file, carbide burr, or other mechanical cutting method to remove oxide. Just brushing, or improper grinding, can drive bits of the oxide into the metal surface. The weld heat will USUALLY do more to the mechanical and chemical properties than the heat from plasma cutting.
