Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. #31
    Sep 2006
    south west Michigan
    81
    What's going to happen to them grinders the first time the power strip is plugged in and you start welding before you hook up the ground?
  2. #32
    not a dam thing. first is if the ground is not on the table you wont have any current obviously. You need a path to carry the circuit back to the welder.
    second reason is that the grinders are insulated. Third is that the power bar has a surge protector on it. fourth is that the voltage output of a welder is low. Welder are low voltage high amperage machines. If they were high voltage low amperage machines than YES it would be a problem. But then we would not have a welder...we would have a neon transformer ballast
  3. #33
    Mar 2007
    Oahu, Hawaii
    2,469
    Yep and the welders things are nothing but a pile of metal
    How come everyone's been to my garage, and no one asked me out for a beer??????
    I'm not late...
    I'm just on Hawaiian Time
  4. #34
    Houston, TX
    900
    Quote Originally Posted by Bryan L View Post
    how much of the corners would you round off?
    I rounded mine to about nickel size, using an angle grinder.
