    Apr 2007
    347
    Default 5-20R Question for You Sparkies
    Is there any NEC code restriction for using 5-20R outlets? Actually, these would be the 5-15 / 5-20 combo type outlets. All my shop wiring is 12AWG/20A breakers. Thanks.
    Millermatic 35
    Miller TB302G
    Ellis 1800
    Smith & Victor Torches
    Optrel Satellite
    Arcair K4000
    Ingersoll-Rand 175CFM Diesel Air Compressor
    Home Made Welding Trailer
    4,432
    As long as you are on 12 I doubt there is an issue.
    Browns Valley, California
    1,713
    You're good to go. The applicable language can be found in Art. 210 of the NEC. On a 20-ampere rated circuit, you can't use a 15-ampere rated receptacle. If what yo have specifies both 15 and 20 ampere ratings, then you're OK.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
    Apr 2007
    347
    Thanks guys!
    Millermatic 35
    Miller TB302G
    Ellis 1800
    Optrel Satellite
    Arcair K4000
