Sorry if a relevant topic already exists but I've spent quite a bit of time searching and can't find it.
Just bought a 1989 Millermatic 200. It has a 3-wire 240v plug. I have no 240v outlet in my home. By code and for safety reasons, if I install a new 240v outlet, it should be 4-wire. How can I convert my welder to a 4 wire plug? Common sense says I need to replace the 3-wire cord and plug with a 4-wire so the real question is how do I connect the white neutral '4th wire' to the welder?
I've never welded before and I'm anxious to start but at my age, I'm very safety conscious.
Thanks!
Brad
11-07-2008, 05:00 PM #1
- Nov 2008
- Virginia
- 2
how to convert my 3 wire Millermatic to 4 wire
11-07-2008, 05:23 PM #2
- Dec 2007
- alabama
- 711
I am by no means an electrician,but none of my 240 volt machines have 4 wires.
XMT 350 cc/cv
XMT 350 vs
TRAILBLAZER 302
MILLER DVI
PASSPORT PLUS
DYNASTY 200 DX
MAXSTAR 150 STL
HOBART CHAMP
HF-251 BOX
12-RC SUITCASES
12-VS SUITCASE
11-07-2008, 05:52 PM #3
what he said.
you can wire it with 4 wires, the 4th wire in the plug is a ground hooked the to box or frame of the outlet, only 3 will go from the plug to the welder. they are just not set up to use an extra ground.
you are thinking
red, black as hot leads
white as a neutral, and green or bare as a ground.
you can do that and the green or ground will end at the plug box. the welder dose not get the extra ground wire. the plug will only have 3 prongs.
hope that helps a bit.thanks for the help
james@newyorkmetalart.com
11-07-2008, 08:40 PM #4
- Jun 2004
- nj
- 204
You need three wires: two phase legs (the hot legs) and one ground
The fourth wire is the groundED (neutral) current carrying conductor, which this machine does not need. It is used only in applications where both 120 and 240V are used by the appliance, and there is no internal transformer to provide the 120V (some electric clothes driers, for example)
The outlet and plug you need is NEMA 6-50 (50A circuit), based on the manual. The wire to the outlet and the circuit protection (breaker or fuse) must be appropriately sized. For a 50A circuit, the minimum size is 8Ga (for most wiring methods). Larger wire is fine, and is desirable for a long run. The machine is rated at 40A input at 240V.
The cord from the plug to the machine can be smaller, based on the rated duty cycle of the machine, but the manual recommends the same 8Ga to achieve rated performance.
The ONLY reason to install a four-wire outlet is if it may be used later for an appliance that requires it. Even then, there is no need to change the cord on the machine... just don't use the un-needed stab (prong) on the plug (the groundED line).
When wiring the plug, check the connections in the machine. Most likely, the cord has a black, a white, and a green. The green should go to the ground point in the machine and to the ground stab on the plug (the round prong that goes in the U shaped hole). The black and the white go to the two current carrying stabs. It is acceptable to use the white wire as a non-grounded current carrying line if it is part of a manufactured cable. For the supply, the white should be relabled with tape or paint to black or red at both ends to show that it isn't grounded. This is not required for the cord, but it is a good idea.
11-08-2008, 08:53 AM #5
- Nov 2008
- Virginia
- 2
3-wire
Got it; thanks. The part I wasn't getting was the purpose of the 4th neutral wire. So, I now have a 50a breaker, a 50a/240v 3-prong outlet and 6ga cable and will get started.
11-08-2008, 11:29 AM #6
- Sep 2005
- 4,242
About the only place you find 4 wire besides feeding panels in residential is cloths dryers and some ranges.
