I use a Lincoln 225 AC Buzz Box. Can it be "souped up" or is it just the way it is? Never having TIG or MIG welded, it is something I'd like to do. Are there any "add-ons" to a Buzz Box?![]()
Results 1 to 4 of 4
Thread: Lincoln AC Buzz Box
11-07-2008, 03:54 PM #1
Lincoln AC Buzz Box
Cantankerous Coot Enterprises
Robert K. Tompsett CEO,CFO,CWM
Lincoln 225 AC Stick Buzz Box
Victor Portable gas welder
Milwaukee Deep Cut Portable Band Saw
Milwaukee Sawzall
2 - Drill Presses
11-07-2008, 03:57 PM #2
- Sep 2005
- 4,242
There are things that are possible but not worth the effort, this was designed as a low cost stick machine, what it does best.
11-07-2008, 09:27 PM #3
- Dec 2007
- PA
- 286
Lincoln AC 225 modifications
Almost any AC welder can be modified to give you DC which opens up the possibility of doing TIG and also providing more selection of DC stick rods.
Many years ago I had an AC only stick welder and I added a full wave rectifier to provide DC. It required 4 large stud mount diodes with 3/4-20 threads to give you an idea of size. I also had to mount the diodes on aluminum heat sinks and insulate them so they would not short out to the welder case.
Back when I did this, I had more time than money so it was my cheap way to start.
After all was done, the welder worked quite well and I was able to TIG using the scratch start method.
After I got better, I saved up and got a used Airco heliwelder as I needed the amperage control capability.
I did the mod in 1978 and the parts cost about $50 plus about a week of work and cussing.
So, yes it can be done but what is your time worth?
Good luck,
Thermal Arc GTSW400, Airco Heliwelder II, Miller Dynasty 350, Hypertherm 1000, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, etc.
11-08-2008, 07:22 AM #4
- Sep 2005
- 4,242
Yes, this class of machine is so competitively priced it isn't worth the effort.
