Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Nov 2008
    12
    Thanks For The Great Info,just Received Mig Welder Today, Clarke 185 Spool Gun,hot Shot ,it Does Have Six Different Settings 30-150 [220] Should Be Able To Weld Just About Anything With It,will Make A T-top For My Boat In The Spring,shorten Radar Arc, Already Have The S.s. Tubing
  2. #22
    Jan 2008
    Colorado
    673
    Thumbs up
    FusionKing:
    I didn't realize that MIG had that much control. For the OP, what filler would you use, 4043?
    You gotta get the toes to wet out over the pores or you will have a perforated line around your work when ground to size. Then that could start a leak/crack in some cases (pun intended).
    This is the OP's first MIG project and is why I joined the thread. Plus the frequent starts and stops. Funny pun.
    Thanks for the detailed description. Spent my career at a desk , so I'm here to learn.
    RETIRED desk jockey.
    Miller Syncrowave 250.
  3. #23
    Nov 2008
    12
    Was Trying Out Mig Welder,is Very Easy,would Reccomend The Clarke 185 Sg
  4. #24
    Jan 2008
    VA
    298
    Time to post some pix of the welds!
  5. #25
    Nov 2008
    12
    Default first time using mig welder
    mig welding exhaust pipe,flux core .030 wire
