Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Nov 2008
    12
    Default What Amps To Mig Weld 1/6 Alum. Jetski Block
    Just Bought A Clarke 185 Sg To Weld Jetski/outboard Motor Blocks,what Amps Should I Use,i Beleive The Mig Welder Welds Between 120-150, Is That Too Much Amps?i Know I Have To Use 100% Argon,not Sure Of Type Of Wire,thanks For Any Help.
    Evansville, IN
    2,348
    I have doubts that mig is going to give you the desired results. Normally casting repairs are done in tig. For wire choice it is going to be a gamble, as it will depend on the base material but maybe 1100.
    6,750
    Yep, Mig isn't going to do you much good, what are you trying to repair on these blocks anyways?
    Nov 2008
    12
    repairing small holes in jetski block,on the outboard motor,have to fill in threaded hole-retap
    Lake of the Ozarks MO
    3,446
    I weld a bunch of these blocks fairly regular. 4043 would be your best bet.
    If you can get it to fuse. Is this the HotShot? I would run it as hot as it would go and then turn it down if needed.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Nov 2008
    12
    ITS THE HOT SHOT MODEL # WE6442 185SG [220] DID NOT RECEIVE IT YET THROUGH THE MAIL,DO THEY MAKE 2 DIFFERENT MODELS ?,THE 1 THAT I BOUGHT DOES NOT HAVE THE LOW AND HIGH SWITCH,BOUGHT IT ON E-BAY FOR 265.00 CAN YOU WELD 1" GAPS WITH A MIG WELDER,NEVER MIG WELDED BEFORE-THANKS FOR THE INFO MY E/M ADDRESS IS KAWIPARTS@AOL.COM
    Evansville, IN
    2,348
    Can these holes not be heli-coiled? a helicoil will a safer repair longterm. My opinion don't kill the messenger.
    Nov 2008
    12
    Quote Originally Posted by Paul Seaman View Post
    only some of them can be heli-coiled
    Jan 2008
    Colorado
    673
    Can you post pics?
    A 1" gap is pretty big, most would build it up with TIG. Cast alum can be 'dirty' and TIG can float the impurities out. MIG is so aggressive, there's no time for that.
    You have never migged before, do you have any welding experience? Don't try learning on an expensive part.
    You can go up to User CP and fill in your location, maybe one of these guys is in your area.
    RETIRED desk jockey.
    Miller Syncrowave 250.
    Nov 2008
    12
    Quote Originally Posted by Craig in Denver View Post
    Can you post pics?
    will post some pics tomorrow,only stick welded before,going to practice on cheap jetski block
