Results 11 to 18 of 18
    Georgia
    4
    Check with your local airport, ask about a prop shop.
    Ask where they send their props. Shouldn't cost too much to have them do it as it won't be going on a airplane, if it was going to be put into service it would have to be balanced.
    Feb 2008
    893
    That'll take a lot of work to look like a good prop again. It does have some real character in its present state.
    Jul 2008
    9
    Thumbs up
    Most modern props are hollow, and some have a composite epoxy poured into the center for strehgth. You need to be really careful in doing that. Even the professionals at museums tend to just replace a prop in that condition. Find a manufacturer's name on it somewhere if at all possible and look them up, they can tell you about the construction technique used and give you the best probable method. My advice, as an aviation mechanic, is to either hang it bent, or remove the good blade and hang that alone. It will look as good, perhaps not as striking as the entire hub, but for your purpose, ****, anything is better than nothing right.
    Akron,Pa
    152
    not to try and steal the thread but we got an old wooden one hanging in my dinning room from when my granddaddy worked at sensenich propeller here in littiz, Pa. This one is when they still made wooden ones the make aluminum ones now. this one is not airworthy.
    http://tinypic.com/view.php?pic=16jg44&s=4
    http://tinypic.com/view.php?pic=2rhsbiq&s=4
    http://tinypic.com/view.php?pic=av4ytt&s=4
    732
    Quote Originally Posted by AM2Mastro View Post
    Thanks for the advice. I was going to call a few folks before attempting to repair the prop. As for hanging the good blade...they are both bent. I will keep everyone posted.
    Thanks again,
    love the look of the old wood ones.
    732
    Here is some additional information on the prop:
    Manufacturer - McCauley
    Serial Number - 807346
    Model Number - 2AF34C55-
    Thanks,
    732
    OK, I spoke to Brian at new england propeller and he said that the propeller is solid aluminum. He said that I should heat it and bend it, I will keep everyone posted...I hope it doesn't break. Well, if it does I guess I will just weld it back together.
