Results 11 to 20 of 23
    Dec 2005
    wisconsin
    830
    Fusion King,
    Well since nobody else has helped, I will try. I checked the drawing for the block in question, and its cast from plain old 356, heat treated to the T-6 condition. So that means:
    1-Preheat to 275 F for about an hour
    2-Weld using 4043 filler and limit the amperage to about 200
    3-Return to the oven for an additional hour after welding, then let it cool in the oven after turning it off.
    This is a common practice to weld on 356 engine castings, done all the time on aircraft engines, and automotive. Good Luck!
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Lake of the Ozarks MO
    3,446
    Quote Originally Posted by Aerometalworker View Post
    Fusion King,
    -Aaron
    Thanks Aero
    strange tho...just got off the phone with chevy parts guy and they said it was 319-T5. (before I came home and read your post BTW)
    If so, that sorta changes everything. 4043 would work still tho.
    Waiting for the Alco-tec tech boys to call back on their filler recommendations at the time.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Dec 2005
    wisconsin
    830
    Well I know the latest LS series is sold as being 319, yet every time I scan a part here at work its 356 or something else. In any event the same filler is normally used with all of those alloys in that family.
    Miller Spot Welder
    3,446
    Alco-tech engineer called back and said 4145 filler with NO pre-heat and at room temp. Only do small amounts and don't let heat build.
    Possibly even PEEN bead only.
    Wildest out of the box thinking that I've heard in a long time.
    I called them because I met the regional manager and I knew he went to Bonnevile speed weeks every year and done a bunch of high tech repairs for that crowd. He happened to be on the phone with whom he considered the best authority he knew on this and tranferred all my info to him. He is the tech guy for Alcotec on fillers/wires etc and has his own biz doing this very thing and was familiar with this block already.
    Before you get all worked up my brother was going on about some company doing top-Fuel block repairs etc and they are submerging blocks except for the weld area and welding them.
    I guess it's all about controlling HAZ.
    Anyhow brother may go ahead and do this himself and upgrade his stuff as needed anyway. He lives about a 100 or so miles from me. So it would be a hassle for me to do it anyways.
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
    Dec 2005
    wisconsin
    830
    Well as I recall 319 does have about 4% copper and about 6% silicon, so 4145 would be more appropriate. However the question still exists of the actual block alloy. I do have some 4145 if you ever need any, last time I bought it it was $26 a pound. The process of welding cold is interesting, and not something I would normally even consider. I wonder if he is suggesting that to preserve the heat-treat in the surrounding material as much as possible? One would think the best bet would be to have the part re-heat treated after welding. Im still questioning the stain gradients with welding a high silicon/copper casting cold, since the entire part is going to "freeze" at about the same moment unlike using a high silicon filler on a low silicon base metal (i.e. 4043 on 6061 ). In the aircraft world we weld cases, and cylinder heads all the time, normally the cases are 356 and the heads are commonly a242, and eveything is pre-heated to various temperatures depending on heat treatment to avoid stress fractures. Its been done that way for many years. I would be very interested to see case studies of the "cold welding" method on cast material, if there are none....it would make me wonder.
    -Aaron
    Miller Spot Welder
    3,446
    -Aaron
    Myself I highly question it. I find people doing wild things and getting away with it all the time. Simply a way to get out of heat treat and whatever else that brings?? It was given to me to do as gospel tho. I guess a search on welding 319 will be needed. I have mixed feelings on this one. Thanks again for the info.
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
    Dec 2005
    wisconsin
    830
    No problem,
    Let me know if you find out any further information. None of my alcoa books even suggests anything like that method, but the newest one is about 8 years old. Im going to pose the question to a co-worker tomorrow, he sits on the aluminum resource board as one of the "fellows".
    -Aaron
    Miller Spot Welder
    3,446
    No problem,
    -Aaron
    Thanks and cool
    I'm gonna call 'em back and dig a little more myself.
    I guess one way to look at it is if it can't grow it can't shrink.
    Sounds more like some of that rollcage junk we were disscussing a few months back but I could be quick to judge.
    Heck and I was thinking the internet was keeping us on the "cutting edge"
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
    Nov 2007
    Saskatoon, Sask, Canada
    1,267
    Very interesting topic, I look forward to see what else you guys can dig up.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Baldwin, NY
    275
    It should be 356, thats what My LS1 is, I am pretty sure the LS7 is the same alloy...
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
