    Default Metal Bender - Part One
    After reviewing a bunch of metal bender designs on this forum and the web, I finally got around to making a Hossfeld-like bender. This one is scaled down somewhat from the full size Hossfeld's and modified. I'm not too sure how thick of material I can bend on it, but it's big enough for what I think I need at this time. This is a work-in-progress, upcoming jobs will likely dictate changes to the design. A design-as-you-go project.
    I'll post a few photos to show some of the design differences from a Hossfeld. All the material, except for the pins and a couple of dies, is scrap I've had laying around. The pins are made from 1144 Stress Free and hardened. I've case hardened (using Kasenit) a couple of the bull nose pieces, but not the dies (yet).
    I think the only real design difference in this bender is the use of the saddles and insert tools. By very carefully spacing holes in the forks (using a vertical mill) I was able to make the saddle pins fit tight in the forks. Then, using a piece of receiver tubing for a clamp, I'm able to make just about any fixture I need - and, these fixtures can have a wide range of adjustment. Lots of flexibility. For sure, the bending capacity is limited when using the saddles above the forks.
    I've mounted the bender in a receiver hitch tube on my welding table (on lockable wheels). Time will tell whether this arrangement will offer enough torque. But, I can rotate the bender in a number of directions to change the position to get more leverage.
    Part Two will be designing a scroll attachment. One that minimizes the amount of flat section on the interior scroll.
    MTBob
    ____________________________
    MM 251 w/Spool gun
    MM 135
    Evolution Cut Off saw
    Logan Lathe
    Clausing Mill
    Walker Turner Drill Press
    3,972
    Nice job on the bender...Bob
    Mar 2008
    Midwest
    109
    A very professional job. I do not have a mill as of yet, but sure want one. My lathe is old but does the job, but I would have to think a good bit before I could build this. Good job.
    Thumbs up
    way cool. did you make the dies also ? looks like a great new tool for the shop.
    MIRABEL , QUEBEC , CANADA
    50
    Very well built , congradulation , looking forward to see more pictures of differents fixtures , keep up the good work.
    FABRICATION-CRÉATION K ZEN
    MILLERMATIC 210
    SPOOLMATE 3035
    SYNCROWAVE 200
    HYPERTHERM 360
    Yes, I made all the fixtures. This project has been kind of interesting since I actually haven't figured out how all the fixtures work on an original Hossfeld. So, I'm kind of inventing how I think the bending fixtures could/should work. I'm still pondering how to make a small pipe / tubing bending fixture and dies to edge bend strap and angle.
    MTBob
    MM 251 w/Spool gun
    MM 135
    Logan Lathe
    Clausing Mill
    Thumbs up
    its cool to have the tool.
    great work.
    3,972
    Here is a link to a Yahoo ornamental iron group and there is a hossfeld manual there. But you must have a yahoo id to get in...Bob
    http://groups.yahoo.com/group/OrnamentIron/
    http://f1.grp.yahoofs.com/v1/cIIPSe8...r%20Manual.pdf
    Thanks Bob! Dang, I'd looked very where to find this manual and couldn't. I'll study this some and think about more mods to the bender I have.
    Bob
    MTBob
    MM 251 w/Spool gun
    MM 135
    Logan Lathe
    Clausing Mill
