The railings look great. The larger diameter will also make a deck ape feel a little more comfortable in rough seas.
Has anyone used hole cutters for coping. Go to www.mcmaster.com and access page 2366 in their online catalog. These are normally used with a mag drill but I have had greats results using them in a mill or even lathe. these cutters are precise with negligible runout and are much heavier than a hole saw. It would take a lot of cuts through any tubing to wear one out.
the carbide would last until you chipped it.
What little coping I have done I have used my milling machine. For small stuff, 1" or less I have used an end mill with great results.
Speeds and feeds is everything in making a cut, not matter what cut you are making. Lubrication and/or coolant is a big factor also. By the time you know your cutting tool is hot, it is too late.
What kind of boat is is going on? Keep the pics coming.
Grits
Results 11 to 12 of 12
11-02-2008, 07:57 PM #11
What boat?
11-04-2008, 04:39 PM #12
I switched to using hole cutters from Kimball Midwest:
http://www.kimballmidwest.com/Catalo...dex.aspx?p=864
I am currently doing a project that will have over 4,000 11/16" holes through 11ga square tubing. About 1/2 way through and the one roto kut I bought for this project is going strong. A bit pricy @ 67 bucks for an 11/16" but I'd be spending a lot more with any other bit. They are very accurate size wise.
