Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Sep 2003
    Bay Area
    38
    Default Dynasty 200DX hidden menu
    Mine is about 3 years old. How do you access the "Hidden Menu"
    Mine is used, without the manual. If I download the correct manual by serial #, does it explain the hidden menu options?
    Jan 2006
    Eugene, Oregon
    2,428
    Quote Originally Posted by GWB View Post
    Yes, it will.
    Dynasty 350DX
    Dynasty 200DX TigRunner
    MM 350P
    MM Passport Plus
    Spectrum 375 Extreme
    08' Trailblazer 302
    Jul 2006
    alaska
    182
    what type of options are we talking about?
    Lake of the Ozarks MO
    3,594
    Quote Originally Posted by 11b View Post
    More than my freekin' brain can handle stuff like start parameters and ramp up times and spot times and all sorts of that sorta stuff.
    It ain't nuthin to download...check it out!!
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Jul 2006
    alaska
    182
    OH OH I am not going to touch that one. I have a hard enough time with the VCR (do we still use these)
    Sep 2008
    Delta B.C.
    33
    There's a short video on it in the right hand corner of this thred.
    http://www.millerwelds.com/resources...ur-skills/tig/
    Millermatic 135
    Nov 2008
    Atl, Ga
    371
    Quote Originally Posted by Rubiconmike View Post
    In the first video, independent EN/EP amp adjustment for AC TIG is the only feature I spotted that doesn't apply to the older models.
    The second video is definitely based on the newer model. My 200DX was made in early '07 and you have to turn the power switch ON, then press process & amps buttons before the meters clear to get into the advanced menu. I can't access my advanced menu with the keystrokes they use in the video with Dig + Amps button (I went to my garage and tried it to confirm).
    The manual (OM-2240) that shipped with my 200DX was NOT an easy read, but I figure it's one of those things you have to "chug through" if you want to use the machine to it's full potential. I've read the book at least a dozen times and I still don't get what you would use the mini-logic function for (page 43). I'll have to call up tech someday and ask them to send me a "Dynasty for dummies " manual - LOL
    Sep 2008
    Omaha, NE
    447
    I found a page online once that i printed but cannot find the link again to post here.
    A few of the ones i like or use are as follows.
    All require turning the machine on while hgolding a combonation of buttons down until the meters clear of teh startup displays
    Reset to factory defaults = Hold process, output and adjust buttons and turn machine on...defaults will be re-set as soon as the machine clears it's displays, I think you also have to shut it off and back on to start welding , but not sure as i've only used reset once
    Gas pre=flow - hold process and adjust and turn on.
    LOw OCV (open circuit voltage) for stick welding and used on "TIG liftarc" if no foot controlo is hooked up and the machine is just set to "on" - access by turning on while holding process, amperage, and adjust buttons - set to either low or normal
    Arc timer - displays the total amount of arc time in hours and shows total number of arcs struck on the machine during it's life span... look in the manual for how to read the time display.. manual # 2240
    TIG start polarity, time and amperage: Turn machine on while holding process and amperage buttons...the first thing to display will be the "start polarity" it will look like "-EN", hit amperage to get to the next item which is "start amperage" (will look like 40 ) and then hitting the amp button again takes you to "start time" again it will be at 40 for default, these are the AC TIG settings... if you switch to DC TIG you will have different defaults..looks like our manuals are similar, go to pages 37 through 39 and you will learn how to do it, the manual is just confusing to read the way they have it layed out.
    I don't really mess with the others and don't even have notes on how to access them without going into the manual and looking.I do know all pages 38 through 56 of PM 2240 are about setting up different items in the hidden menu areas of the dynasty 200 machines (the preflow is a 200 series only thing since other dynasty models have a "pre-flow" button on them
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
    Nov 2008
    New Hampshire
    29
    Do the older Dynasty's have these menus? man i feel left out...
    Kelly
    Trailblazer 301D
    2 XMT 304's
    Dynasty 300 Tigrunner
    Spectrum 2050
    XR with ALUMA-PRO
    12RC suitcase
    Millermatic 251
    60a feeder
    Ellis 1600
    Bridgeport
    16" southbend
    Too many Hand tools...
    3,594
    Quote Originally Posted by pyro2 View Post
    yep they do
    Miller WC-115-A
    Miller Spectrum 300
