Results 1 to 8 of 8
    Jun 2005
    Nesconset NY
    74
    Default Looking to build a tig cooler
    I am looking to build a tig cooler for a SD 180.I am looking for a parts list/photos and some direction.Thanks
    Texas
    279
    This will get ya started
    http://www.millerwelds.com/resources...ead.php?t=6728
    do a search for threads started by Sundown ,for a parts list and other info on the subject. Sadly George pass away but some where there is a complete write up he and another fellow did on the project.
    Good luck
    L*S
    edit: found the article
    http://www.thefabricator.com/ArcWeld...le.cfm?ID=1275
    Jan 2008
    Colorado
    673
    Leon:
    I think of Sundown everytime someone asks about a homemade watercooler.
    I'm glad you found the link.
    RETIRED desk jockey.
    Miller Syncrowave 250.
    Sep 2008
    Anchorage, Alaska
    98
    Default My Homemade Cooler
    I am new at TIGing & wanted a water cooler, also. I built the one in the accompanying photo. I did the welding with a 17 series aircooled torch - Yepper, looks like bird dodo to me too (My first aluminum welds)
    Motor & Pump 220volt -- $125 (counting shipping to Alaska)
    Fan 220 Volt ------------- 25
    Heater Core -------------- 20
    Aluminum Box Tube ------- 15
    Aluminum Scraps -------- free
    Assorted Fittings --------- 25
    Hose --------------------- 4
    Took several sessions & quite a few redesigns in my head to make it work. That fan is rated at 300 cfm. I do not know if the reservoir would even be necessary. That baby really moves some air.
    I wanted everything 220 so I could wire it into the cord for the Dynasty 200. It works fine -- no overload problems at all. The pump & fan only draw 2-3 amps.
    I gained a lot of experience with this project, but in reality, based on the cost of the parts, the agron & filler, along with the electricity used, it may just have been cheaper to have purchased one premade. But then, I wouldn't have learned diddly-squat about aluminum welding either.
    Jerry in Anchorage
    May 2008
    Fredericton, NB Canada
    124
    Quote Originally Posted by muskt View Post
    Jerry in Anchorage
    Hi Muskt -
    Where did you order / get your components for this cooler ?
    Thanks,
    Lewis
    Sep 2008
    Anchorage, Alaska
    98
    Default Parts for Cooler
    I got the pump/motor combo on EBay. Search for "tig pump or procon pump or tig pump". (You may be surprised how some folks list the same items.) I ran the cord for the pump & fan right alongside the cord for the Dyn. I mated both cords into one plug so that the fan/pump runs continuously whenever the Dyn is plugged in. Works great & NO HEAT buildup around the plug.
    The fan from the Surplus Center.
    http://www.surpluscenter.com/
    The rest around Anchorage.
    That Surplus Center has lots of great "stuff" at pretty decent prices.
    There are probably many many more methods for making a cooler than that which I pursued. Since I live in Alaska, I even considered not using a fan at all. It rarely gets more than 65-70 F in my garage. Since I am only a Tinkerer & don't weld big things (usually), I haven't even been able to detect any warming of the hoses going into the cooler from the torch.
    Jerry in Anchorage
    (+8F this morning at my Igloo)
    Nov 2003
    3,633
    Default cooler
    Hi
    if you want to save some money on the pump... look for a "Procon" carbonation vane pump (40psi if I recall) your local junk store or ebay for about $50... from soft drink soda fountains...
    hope this helps
    Heiti
    Nov 2003
    3,633
    Sorry Muskt.. we must have posted at the same time..
    Heiti
