Results 1 to 10 of 14
    S.W. Pennsylvania
    2,250
    Default catalytic converter
    A friend wants me to weld a threaded bung to accept an oxygen sensor into a catalytic converter. I'm sure the stuff is galvanized or coated somehow.
    I was wondering if anyone brazes them in, or is welding the ticket. I would be tig welding if I go that rout.
    To all who contribute to this board.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Jan 2008
    VA
    298
    Add the bung just up stream or just down stream of the cat dependong on its use, not into the cat container itself. I don't think there would be a heavy coating of zinc if any on ex pipe. Zinc and many other metals can damage a cat. I have added bungs on a few with no issues. Any method will require you to clean the surface to the base metal so overall it is not a real issue. Welding is prefered IMO.
    Weekend wannab racer with some welders.
    S.W. Pennsylvania
    2,250
    Quote Originally Posted by Vicegrip View Post
    Thanks.
    I think he did mention that it was in a short piece just before the converter.
    I guess I will weld it.
    Pureox OA
    Dec 2005
    San Diego, CA
    168
    Default Cats...
    I have a '96 Jeep that the cat starting making a nasty rattle when you shut it down. I unfolded the seam on the outer cover and removed it, used a grinding wheel to slit open the cat and found the covering on one of the ceramic sections was gone. I wrapped it with an industrial product called fiber-fax and tigged it back together. My guess from cutting it open was it was some sort of stainless, I used 308L filler to weld it back together. The cat itself wasn't galvanized just the outer cover which I replaced and re-crimped the edges.
    I wouldn't think welding in a bung for the o2 senser wouldn't be a problem. Worse issue would be to issue you hit open space in the cat.
    Frank
    (aka Fred)
    MM200 (antique and still cook'n)
    Lincoln 160 buzzzzzz box - left to live with a nice youngster
    Dynasty 300DX
    Spectrum 625
    Chevalier Knee Mill - Bridgeport clone you idiot.
    Homebuilt tube bender - with home made dies no less
    Delta Drill Press & Grinder collection
    Needed - a bigger shop to use the stuff
    Sep 2008
    Omaha, NE
    447
    I build a lot of custom down-pipes (exhaust tube from turbo to cat) and high flow cat installs. There are 2 O2 sensors..*at least on a 4 cylinder* One is upstream more to the motor side and reads air fuel ratios for the engine's ECU to adjust delivery to maintane the correct AFR. The downstream one (behind the cat) is just there to make sure the cat is working. If the readings are too close between the 2 sensors the ECU knows there's no cat on the car, or that it is not working and signals a "check engine" light.
    As for welding them.. on pla in exhaust i MIG them just inside of the open garage door, this way I don't breathe the fumes of any coating burning from the pipe. The one exception would be when i do stainless setups for people, then i TIG it because there's no galvanizing or anything like that on stainless parts.
    Hope this helps
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
    Just about every other hand tool you can imagine
    Apr 2006
    Central NJ
    73
    Default info
    Most newer pipe is what they call aluminized, not galvanized. I've welded lots of it. No fumes and no grinding or cleaning it before welding, just mig right thru it.
    S.W. Pennsylvania
    2,250
    Thanks for all the replies guys.
    The bung is going on the exit end of the cat. I wanted to put it into a separate adapter pipe but the way it is I think I will have to put the bung in the exit pipe on the cat itself and then weld the adapter pipe on. The pipe comming out of the cat is a gold color, like a grade 8 bolt.
    This guy is my best friend and he's really pissed at himself for how he ended up in this position. He was doing this for his daughter and trying to save money. After going through the first car bit for three other kids before her, he knows how you can waste a lot of money for nothing.
    He now wishes he had just bought a whole new exhaust. This universal cat was less than half price of the one that is made for it and the guy that sold it to him said they just cut the O2 sensor off. My buddy bought it not thinking that down here there is no emission inspection and up where he lives that wont fly.
    Pureox OA
    Jun 2006
    Maine
    732
    most aftermarket (if not all) convertors are have a shell of 409 stainless which is a non-austentic and ferritic... meaning a magnet will stick to them.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    S.W. Pennsylvania
    2,250
    Well, its welded in and everything went alright, the senser screws in OK. I ran compleetly out of argon on this, the gage has been on 0 for a while now, I know what I'll be doing tomaro.
    Pureox OA
    Apr 2006
    Central NJ
    73
    Default Well now
    That looks better than factory. Good job and I'm sure he'll be happy with it.
