A friend wants me to weld a threaded bung to accept an oxygen sensor into a catalytic converter. I'm sure the stuff is galvanized or coated somehow.
I was wondering if anyone brazes them in, or is welding the ticket. I would be tig welding if I go that rout.
Results 1 to 10 of 14
Thread: catalytic converter
10-30-2008, 06:13 AM #1
- Sep 2005
- S.W. Pennsylvania
- 2,249
catalytic converter
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
10-30-2008, 06:25 AM #2
- Jan 2008
- VA
- 298
Add the bung just up stream or just down stream of the cat dependong on its use, not into the cat container itself. I don't think there would be a heavy coating of zinc if any on ex pipe. Zinc and many other metals can damage a cat. I have added bungs on a few with no issues. Any method will require you to clean the surface to the base metal so overall it is not a real issue. Welding is prefered IMO.
10-30-2008, 06:48 AM #3
- Sep 2005
- S.W. Pennsylvania
- 2,249
Last edited by burninbriar; 10-30-2008 at 06:50 AM. Reason: Question already ansered
Pureox OA
10-30-2008, 11:47 AM #4
- Dec 2005
- San Diego, CA
- 168
Cats...
I have a '96 Jeep that the cat starting making a nasty rattle when you shut it down. I unfolded the seam on the outer cover and removed it, used a grinding wheel to slit open the cat and found the covering on one of the ceramic sections was gone. I wrapped it with an industrial product called fiber-fax and tigged it back together. My guess from cutting it open was it was some sort of stainless, I used 308L filler to weld it back together. The cat itself wasn't galvanized just the outer cover which I replaced and re-crimped the edges.
I wouldn't think welding in a bung for the o2 senser wouldn't be a problem. Worse issue would be to issue you hit open space in the cat.Frank
(aka Fred)
MM200 (antique and still cook'n)
Lincoln 160 buzzzzzz box - left to live with a nice youngster
Dynasty 300DX
Spectrum 625
Chevalier Knee Mill - Bridgeport clone you idiot.
Homebuilt tube bender - with home made dies no less
Delta Drill Press & Grinder collection
Needed - a bigger shop to use the stuff
10-30-2008, 11:52 AM #5
I build a lot of custom down-pipes (exhaust tube from turbo to cat) and high flow cat installs. There are 2 O2 sensors..*at least on a 4 cylinder* One is upstream more to the motor side and reads air fuel ratios for the engine's ECU to adjust delivery to maintane the correct AFR. The downstream one (behind the cat) is just there to make sure the cat is working. If the readings are too close between the 2 sensors the ECU knows there's no cat on the car, or that it is not working and signals a "check engine" light.
As for welding them.. on pla in exhaust i MIG them just inside of the open garage door, this way I don't breathe the fumes of any coating burning from the pipe. The one exception would be when i do stainless setups for people, then i TIG it because there's no galvanizing or anything like that on stainless parts.
Hope this helpsDynasty 200DX
Hobart Handler 135
Smith MB55A-510 O/A setup
Lathe/Mill/Bandsaw
Hypertherm Powermax 45
10-30-2008, 01:33 PM #6
- Apr 2006
- Central NJ
- 73
info
Most newer pipe is what they call aluminized, not galvanized. I've welded lots of it. No fumes and no grinding or cleaning it before welding, just mig right thru it.
10-30-2008, 02:52 PM #7
- Sep 2005
- S.W. Pennsylvania
- 2,249
Thanks for all the replies guys.
The bung is going on the exit end of the cat. I wanted to put it into a separate adapter pipe but the way it is I think I will have to put the bung in the exit pipe on the cat itself and then weld the adapter pipe on. The pipe comming out of the cat is a gold color, like a grade 8 bolt.
This guy is my best friend and he's really pissed at himself for how he ended up in this position. He was doing this for his daughter and trying to save money. After going through the first car bit for three other kids before her, he knows how you can waste a lot of money for nothing.
He now wishes he had just bought a whole new exhaust. This universal cat was less than half price of the one that is made for it and the guy that sold it to him said they just cut the O2 sensor off. My buddy bought it not thinking that down here there is no emission inspection and up where he lives that wont fly.To all who contribute to this board.
Pureox OA
10-30-2008, 03:47 PM #8
most aftermarket (if not all) convertors are have a shell of 409 stainless which is a non-austentic and ferritic... meaning a magnet will stick to them.
Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
10-30-2008, 05:52 PM #9
- Sep 2005
- S.W. Pennsylvania
- 2,249
Well, its welded in and everything went alright, the senser screws in OK. I ran compleetly out of argon on this, the gage has been on 0 for a while now, I know what I'll be doing tomaro.
Pureox OA
10-30-2008, 07:35 PM #10
- Apr 2006
- Central NJ
- 73
Well now
That looks better than factory. Good job and I'm sure he'll be happy with it.
