Results 1 to 7 of 7
    6,755
    Default Working pressures
    What is the max working pressures in PSI after the bottles of an Oxy/Acetelene system say for cutting or preheat applications.
    Having Reels built and manufacturer needs to know
    Queens NY
    1,547
    acetylene is a no-no over 15 PSI. Oxygen i've heard but never used 40+ psi for big cutting torches. i usually need 15-20psi for the limited cutting i do.
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    Sep 2002
    Clark County, NV
    2,696
    Yep. Acetylene redlines at 15 PSI, but obviously the gear will be built to take more than that. No redline on oxygen, but 100 PSI should do about ANYTHING; as mentioned, most of my stuff is also less than 25 PSI.
    4,247
    I would say they need to be designed for 100 working # at least and for sure on the O2.
    6,755
    Well I've told the manufacture 100psi, it's not the reel itself rather the coupler swivels. They wanted to know whether or not they could go brass instead of the usual steel fittings and pressures
    Nov 2007
    Saskatoon, Sask, Canada
    1,267
    Sounds like it will work, let us know how they turn out.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Jun 2006
    Maine
    728
    brass would be the better material as it's non sparking and should easily handle the working pressures you're talking about. We use brass swivels in our carwash equipment all the time and those see 1500PSI, day in, day out.
    as for the pressures I run.... if it's something heavy, like lopping off the end of a W24X162 beam, I'll be running 10PSI acetylene and 80 or so PSI oxygen with a #6 tip. at it's thickest point, a W24X162 is about 2" thick at the web to flange radius....
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
