Page 1 of 6 123456 LastLast
Results 1 to 10 of 52
    Apr 2007
    NJ
    23
    Default Tungsten sharpening
    Hi guys, I'm on the site alot reading , but never posted much. I've been around drag racing for many years now and also race. I do some tig welding in my home shop, have a dedicated grinding wheel for my tungstens and sharpen them vertical to the wheel. I've been in alot of chassis shops (some well known) and see the tungstens held horizontal to the belt sander. The same belt sander they use to debur, remove chrome moly, mildsteel etc. and their welds come out beautiful. Here's the question, what's the right way and does it really matter.
    Mar 2006
    Queens NY
    1,547
    I'm a little curious too, i have alays sharpened mine along the length with a belt sander or diamond wheel. recently i started a TIG class and the instructor sharpens his on a grinding wheel that is not dedicated, he uses a slight angle from parallel and has clear spirals. Another welder who is a certified AC welder with over 40 years of experience showed my friend the same technique and makes his point slightly convex. They both use a very long taper. I have always gone by the Miller/diamond ground reccomendations. I wonder if there is any advantage to each method.
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    Mar 2006
    La Porte, Tx.
    56
    We've always used a bench grinder to sharpen the tungsten, personally I point my tungsten up into the wheel, resting my hands on the table, I also use a twist drill holder to grip the tung. and rotate it.
    I like to take mine to a fairly decent needle point, also when sharpening with the point "up" into the wheel the material removed goes away from the finished point instead of down and collecting on the point if you held the tung. down.
    Holding the tung. level/ perpendicular to the wheel is the way I use to do it, but I found I could do a better job vertically.
    pull-do
    National City CA
    1,086
    The text book answer is grind it in the direction of the rod not perpendicular to the rod.
    But it comes down to this One is the grit of the abrasive you are using. Too course will foul things up either way you grind it. so if there is a fine enough abrasive it wont matter much. Then there is the matter of what you are welding and how many amps you are using. The more power put through the tungsten the less the grind matters.
    Either way I use a bench grinder and grind it like the book shows, Inline with the rod and always finish it up on the fine wheel.
    Miller Syncrowave 200 W/Radiator 1A & water cooled torch
    Millermatic 252 on the wish list
    Bridgeport Mill W/ 2 axis CNC control
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Over 20 years as a Machinist Toolmaker
    A TWO CAR garage full of tools and a fridge full of beer
    Auto shades are for rookies
    www.KLStottlemyer.com
    Austin, TX
    621
    I am ready to get a freakin' Sharpie. I spend way to much time grinding my tungsten. I guess I don't have a steady enough hand but it's been years since I last sat at a table.
    Miller Maxstar 200 DX
    RMLS-14 Momentary Hand Control
    Miller Syncrowave 180 SD
    Porter Cable 14" dry metal saw
    Hitachi 4.5" grinder
    http://mhayesdesign.com
    Nov 2006
    Lake of the Ozarks MO
    3,528
    Here is my take on tungsten grinding technique...the shape matters more than the method.
    Once you get so good that the only area you could improve your welds is the little inconsistencies in your tungsten surface then you would be wise to spend your time on that.
    I have laid down some of my best beads ever, that nobody will ever see, using a 4 1/2" grinder loaded with aluminum with one hand and tungsten in the other because I was simply too wore out to crawl out from under the boat on a trailer and use a better method. SAFE? NO! PERFECT SHAPE? NO!
    BUT... perfect enuff to get done and get paid
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    http://millerwelds.com/education/tec...ps/setup.html\
    There information is itself on this site you just need to look for it. I myself have a wheel that all it is for is shaping nothing more. Vert or horiz. Makes a big difference when your welding AC in my experience DC its makes a difference but for myself not noticeable. For the guys using Flapper wheel or belt sander you stop preppin your welding material as well cause your loading your tung with what ever is on the belt of flapper so why put forth the effort for a clean weld when you cant go the extra step in your tung prep.
    Nov 2006
    3,528
    Quote Originally Posted by Champagneracing View Post
    You really aren't that far off...There are loads of times I don't do hardly ANY prep whatsoever on the base material. AC cleans good enuff to lay down acceptable welds in many situations. Not everything is the freakin' space shuttle and not everybody is willing to pay you to screw around with laying perfect beads. They just want it to be welded strong and look reasonably well at a reasonable price.
    There are many times I have gotten everything absolutely perfect only to dip tungsten right off the bat
    I can get as persnickity as anybody...but....I only get paid for the jobs I finish. I normally sharpen both ends of my tungsten in a cordless with a dedicated bench grinder btw.
    I still have a ton of work from as far back as November left to do. Every stinkin' time the sun shines my phone goes crazy. My customers LOVE my dirty unprepped welding
    Truth is if I could weld things and make them look as tho they had NEVER been welded (ie undisturbed patina) I could charge a bunch more
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
    Mar 2007
    Oahu, Hawaii
    2,469
    Awww...c'mon....
    PICS!
    PICS!
    PICS!
    PICS!
    I'm not late...
    I'm just on Hawaiian Time
    Austin, TX
    621
    x2 on the pics. I cannot visualize this, and now I'm curious.
