I started it today after scrounging parts and a core old stove that has seen its share of modifications from several different installations. I didnt want to start from scratch so I am adapting and took the plasma to it to make changes, spent an hour with a grinder and am getting ready to retro fit the features I need, enlarge the door, add some baffles and put it into a jacket for forced hot air outside wood burner. These are some of the core parts, junk laying on top of the stove.
Results 1 to 10 of 35
Thread: Wood furnace
10-23-2008, 04:18 PM #1
- Sep 2005
- 4,246
Wood furnace
10-23-2008, 05:51 PM #2
Starting to get cold here and I've been thinking of the same thing to help suplement the LP heat in my shop. Keep us posted on your project....
10-24-2008, 09:21 AM #3
- Sep 2005
- 4,246
I cut the scrap off and opened the door height, now trying to come up with a baffle design that I can install before I rebuild the door front. I am wanting the hot exhaust to run down the full length of the top plate before it exits. The baffle will be like a channel or box tubing about 2x12 about 20 inches long.
10-24-2008, 11:20 AM #4
looks like you are off to a good start.
will it be inside your home or for the shop??
how thick is the fire box ??
i been playing with the idea of making a burner to heat water to circulate as a heat source. still need to do a lot of info gathering be for i attempt it though. lots of unanswered questions be for i start.
james@newyorkmetalart.com
10-24-2008, 11:27 AM #5
- Sep 2005
- 4,246
Its for my house, it will sit outside and duct into the central. This is a really simple hillbilly version. I live in a mobile home (was cheap to free) and have about 8 ft run to make it to the raceway. I am going to have to cut a hole in the frame to duct thru to make it direct. I was going to build an addition and incorporate all this in with a utility room but an going to do shortcut version for the time being, ran out of money and ambition.
10-24-2008, 11:46 AM #6
i just added an 8'X12' addition to my trailer this summer for my 3 year old to have a room. its the 2nd time i have done this, i'm running out of trailer.
i was thinking an outside boiler then pipe the hot water into the house to help off-set the $ of the heating oil as its killing me.
i just ran out of time and $$ to get it done this summer, so its a next year thing i guess. unless i build it in the shop and attach it later.
11-11-2008, 12:26 PM #7
- Sep 2005
- 4,246
I am seeing if I can find the pics from the progress. I need it working, the cold is coming and I cringe when the gas unit comes on. Camera is giving me fits,,, be back.
11-11-2008, 03:36 PM #8
- Sep 2005
- 4,246
Ok, getting ready for the insulation. Am going to add the fan thermostat yet, a thermo from a water heater. Ist pic was jacking the baffle plate in.
11-11-2008, 04:22 PM #9
I love it! i'd rather spend my money on a cool wood stove knowing the oil company won't be reaching into my pocket, i just wish miller would make a trailblzer that could run on wood
i'd mount it on a stanley steamer, and drive by the gas station with it running, laughing....
Looks good so far! keep us postedKelly
Trailblazer 301D
2 XMT 304's
Dynasty 300 Tigrunner
Spectrum 2050
XR with ALUMA-PRO
12RC suitcase
Millermatic 251
60a feeder
Ellis 1600
Bridgeport
16" southbend
Too many Hand tools...
11-11-2008, 04:59 PM #10
Hey Fun,
This is extremely common in New Zealand.It is called a "wet back". All you need is a wood stove and you incorporate a supply line that is in contact with the wood stove and an insulated holding tank similar to the hot water heater tank you now have.
Thanks,
Nick
