Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: Wood furnace
    4,246
    Default Wood furnace
    I started it today after scrounging parts and a core old stove that has seen its share of modifications from several different installations. I didnt want to start from scratch so I am adapting and took the plasma to it to make changes, spent an hour with a grinder and am getting ready to retro fit the features I need, enlarge the door, add some baffles and put it into a jacket for forced hot air outside wood burner. These are some of the core parts, junk laying on top of the stove.
    Dec 2006
    Traer, IA
    312
    Starting to get cold here and I've been thinking of the same thing to help suplement the LP heat in my shop. Keep us posted on your project....
    4,246
    I cut the scrap off and opened the door height, now trying to come up with a baffle design that I can install before I rebuild the door front. I am wanting the hot exhaust to run down the full length of the top plate before it exits. The baffle will be like a channel or box tubing about 2x12 about 20 inches long.
    Aug 2006
    near rochester NY
    9,881
    Thumbs up
    looks like you are off to a good start.
    will it be inside your home or for the shop??
    how thick is the fire box ??
    i been playing with the idea of making a burner to heat water to circulate as a heat source. still need to do a lot of info gathering be for i attempt it though. lots of unanswered questions be for i start.
    4,246
    Its for my house, it will sit outside and duct into the central. This is a really simple hillbilly version. I live in a mobile home (was cheap to free) and have about 8 ft run to make it to the raceway. I am going to have to cut a hole in the frame to duct thru to make it direct. I was going to build an addition and incorporate all this in with a utility room but an going to do shortcut version for the time being, ran out of money and ambition.
    Aug 2006
    near rochester NY
    9,881
    Cool
    i just added an 8'X12' addition to my trailer this summer for my 3 year old to have a room. its the 2nd time i have done this, i'm running out of trailer.
    i was thinking an outside boiler then pipe the hot water into the house to help off-set the $ of the heating oil as its killing me.
    i just ran out of time and $$ to get it done this summer, so its a next year thing i guess. unless i build it in the shop and attach it later.
    4,246
    I am seeing if I can find the pics from the progress. I need it working, the cold is coming and I cringe when the gas unit comes on. Camera is giving me fits,,, be back.
    4,246
    Ok, getting ready for the insulation. Am going to add the fan thermostat yet, a thermo from a water heater. Ist pic was jacking the baffle plate in.
    Nov 2008
    New Hampshire
    29
    I love it! i'd rather spend my money on a cool wood stove knowing the oil company won't be reaching into my pocket, i just wish miller would make a trailblzer that could run on wood i'd mount it on a stanley steamer, and drive by the gas station with it running, laughing....
    Looks good so far! keep us posted
    Kelly
    Trailblazer 301D
    2 XMT 304's
    Dynasty 300 Tigrunner
    Spectrum 2050
    XR with ALUMA-PRO
    12RC suitcase
    Millermatic 251
    60a feeder
    Ellis 1600
    Bridgeport
    16" southbend
    Too many Hand tools...
    Aug 2007
    673
    Quote Originally Posted by fun4now View Post
    Hey Fun,
    This is extremely common in New Zealand.It is called a "wet back". All you need is a wood stove and you incorporate a supply line that is in contact with the wood stove and an insulated holding tank similar to the hot water heater tank you now have.
    Thanks,
    Nick
