Results 1 to 10 of 14
    Default hi all newbie here
    hi all, im a on again off again welding student at the local community college, i picked up a old miller thunderbolt, i was curious if i could update it some, it has a hand crank power control but the cheesy indicator doesnt work, is there anyway i can wire in a ampmeter if so how would i do this? any help is appreciated
    Los Angeles
    2,967
    Welcome to the Forum.
    Sorry- can't help ya out
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Jul 2008
    Delhi, Ontario:
    1,998
    Thumbs up nfinch86- CANADIAN WELDOR :
    Quote Originally Posted by lonegunman88240 View Post
    HI & WELCOME; Where ya from??..... Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    WY...armpit of U.S.A.
    659
    Have you pulled the cover to see what exactly is wrong with the indicator? Might be cheesy for you, but it is dead simple and should be both easier to fix and cheaper using the original pointer.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    thanks for the warm welcome, im from hobbs new mexico,
    yea actually i have, the guy i got it from was welding on a horse trailer and forgot about it, and somehow ran over it, everything seems fine but the case is messed up, will be making one soon, it seems to me that the front plate moves forward and backwards depending on which way it is cranked, whick forces a a small indicater into position i assume? most of those small parts are gone and the local welding shops were no help
    659
    Post up a picture and lets see what you have left.
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
    ok just as soon as i can, he didnt run completly over it just enough to ruin the case, he tried to reshape it and hammer it back to shape lol and it looks it,
    i got a 100 amp fcaw, i thought making a new case would be a good project for the little wire feed, would any of you know what the duty cycle of these old welders were?
    659
    Click on the link below, find your welder and enter the serial # and the owner's manual that will come up should give you specifics on your model.
    http://www.millerwelds.com/service/ownersmanuals.php
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    You should be able to get parts from Miller pretty easily.
    You could send cruizer on this board a private message, he could tell you right away if there was an easy way to rig something else up. He's a certified Miller repair tech so send him as much info as you can, if nothing else he can give you the part #'s to get the correct pieces to repair it back to original.
    Good luck.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
