Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Deltaville, VA
    2,239
    Justin,
    There's a company called SoundDown (located in FL I think) that specializes in reducing noise levels from boat engine rooms. They sell a lead shield, foam backed product that does a tremendous job. Seems the real trick is to search out and eliminate all free air flow. They actually showed me with their equipment how much noise will travel through a 1/4" dia. hole.
    I used them to insulate the engine room on a 72' Bertram Convertible I sold to a European client. Good people to deal with.
    I'd do an internet search and contact them with your information.
  2. #22
    May 2008
    Belle Plaine Iowa
    270
    Are you sure you want to sound proof a dyno room? Can you imagine how lowd it will be when you open the door and all that sound comes out at once?
  3. #23
    Jun 2006
    Killingworth,Ct.
    372
    Default Sound Room
    Ive done a few radio stations, Many Moons ago,and we used sheet lead, almost what a good mason uses for flashing,,Light enoung to roll out,and staples it to the doors,that we insulated the inside!!!!!!!!! worked great,couldnt here the cop cars go buy all day,as the studio was close to the main drag!!Just my 2 cents!:
  4. #24
    Mar 2013
    4
    The sound of door can be reduces in number of ways. Such as use of carpet
    piece on the bottom of door reduce its resistance, which reduce the sound.
