Results 1 to 8 of 8
    Feb 2008
    8
    Default 3/8" Fillet In a Single Pass?
    What machine and stick rod would you use to get a 3/8" fillet on mild steel in a single pass? I'm talking about a field job, diesel machine.
    Or do you think we would be better off with a flux core MIG?
    Thanks!
    Mar 2008
    Anchorage AK
    344
    AWS D1.1: This is not allowed, and for good reason from my own experience. AWS D1.1 wants to see no more than 1/4" for SMAW and no more than 5/16" for FCAW/GMAW. After that multipass with continuous inspection.
    Carrying that much filler "can" lead to issues of hollow beads, cold lap, non fusion at the root.
    Can it be done? sure, why would you want to????? Why not do a simple three pass with 1/8"7018. Proven winner simple and cheep equipment, rentable in most every county in the western world.
    5/64" FCAW NR233/232 or Coreshield 8 vary doable more so vertical up.
    I do not recommend doing this with out a lot of experience.
    TJ
    Jun 2004
    nj
    204
    I would multipass it, probably about 3 passes 5/32 7018. Could do it with 1/8, as well. 3/32 would take forever. Three passes with fluxcore would be faster.
    IF the weld is in flat position, and you HAD to do it in single pass stick, you COULD do this with 3/16 or 7/32 7024, presuming a heavy enough power source.
    [QUOTE=FATFAB;162032]AWS D1.1: This is not allowed, and for good reason from my own experience. AWS D1.1 wants to see no more than 1/4" for SMAW and no more than 5/16" for FCAW/GMAW. After that multipass with continuous inspection.
    FATFAB,
    That's not exactly what AWS D1.1 says. For SMAW (and others)you are allowed up to a 1/2" single pass fillet, depending on position. Take a look at table 3.7. Also, there is no requirements for inspection, continuous or otherwise, in AWS D1.1.
    [QUOTE=hogan;162036]
    Quote Originally Posted by FATFAB View Post
    FATFAB,
    That's not exactly what AWS D1.1 says. For SMAW (and others)you are allowed up to a 1/2" single pass fillet, depending on position. Take a look at table 3.7. Also, there is requirement for inspection, continuous or otherwise, in AWS D1.1.
    Right, that isn't what D1.1 says that I can find and..... right again Table 3.7 disputes those numbers but even then....the limits in Table 3.7 are for PREqualified WPS'. I believe you can easily qualify your procedure with larger fillet size than those listed in the table.
    To the original question, if i was wanting to make 3/8" single pass fillet welds I'd use, without question, flux core wire, either NS3M or (much more likely)311Ni.
    I've run quite a bit of 311Ni in 5/64" size and it is a very high deposition wire in flat/horizontal positions, and meets the harshest seismic requirements.
    311Ni also gives you more bang for the buck if you are limited amperage wise, it makes a 250 amp machine behave like a 300 amp machine as it has high deposition at (relatively) lower amperages. It tends to run a lot like Lohi but handles gaps and corners quite a bit better.
    This is a money making wire when you have a "lot" of "large" structural fillets to make.
    JTMcC.
    Some days you eat the bear. And some days the bear eats you.
    Jul 2008
    Delhi, Ontario:
    1,969
    Cool nfinch86-CANADIAN WELDOR :
    Quote Originally Posted by Iron Head View Post
    If you can get your hands on an old Commander 500 or Vantage 500 with either an LN-7,8,9 or 25 with either of these wires, you should be able to place an honest 3/8-inch fillet in the flat position running about 12-inches in under a minute easily!
    Do you know what a hand protector is?
    YEAP!!! SUFFERED A FEW BLISTERS on the Back of my Hand back 1970's Welded 8 inch thick Steel Laddles- Buckets in the steel co. of Canada-Lake Erie Works, One week each side, Double-Vee. Lots Of Fun ?.... Norm :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Jun 2008
    12
    Default 3/8 pass
    I work at Crown equipment corp. and we make 3/8 passes with flux core all the time in flat mainly but in any other position that has to be done with it. and we have robots that make passe the are inch and bigger with single passes, so its not that out their and i dont know the code but its i big company and iam sure they wouldnt let us do anything against it.
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    [QUOTE=JTMcC;162042]
    Quote Originally Posted by hogan View Post
    JTMcC.
    WOW!!! I can't believe JT recommended flux core!!! Next thing he'll be buyin a blue welder... don't worry JT I won't hold my breath!
    Sorry buddy, I couldn't resist.
    at home:
    2007 302 Trailblazer with the Robin FOR SALE
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
