Results 1 to 10 of 13
Thread: boiler repair
    Jul 2004
    Jackson, MI
    46
    Default boiler repair
    tomorrow I have to weld closed a 1/2 inch hole in a large boiler tank. I think it is most likly cast iron but I haven't seen it yet. DC stick is the mechine I have avalible. Rod and setting would be greatly helpful thanks, NICK
    Jul 2008
    Delhi, Ontario:
    1,998
    Thumbs up nfinch86- CANADIAN WELDOR :
    Quote Originally Posted by sparky123 View Post
    HI; CAST IRON - Ni-Rod a couple different kinds; Ni-55, Ni-99 & so on..... Norm : SETTINGS?.. SIMILAR to 7018 if I recall :
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Jun 2004
    nj
    204
    Is this a pressure retaining part? If so, you may be in a world of liability touching it.
    I am presuming, based on your question, that you have not been given clear detail about the material, required procedures, etc. If you are in Michigan, you MUST have authorization (NBIC 'R' stamp or Mich state, according to my ref book...) and approved procedures ('R' stamp: generally ASME Sec IX, unless the manual specifies other options.... State: my ref doesn't say, other than to note that the state accepts ASME Sec IX)
    If it is NOT pressure retaining, you may still want to consider carefully, if it is a part that could be safety critical.
    Mich law: http://www.legislature.mi.gov/(S(wdw...me=mcl-408-768
    Jun 2008
    Mount Clemens,Mi
    350
    Here is the other rules and admincode http://www.state.mi.us/orr/emi/admin...pt=CI&RngHigh=
    Has having spent 34 plus years operating boilers in the state of Michigan. If you aren't licensed to do it you don't want to touch it.
    From the sound of it cast iron. It probably is a cast iron sectional boiler. Which if it is we would take a section that was leaking out. Put new gaskets in and put it back together. as welding them never was satisfactory. And you never can seem to find a new replacement section.
    glen, If your not on the edge, your wasting space
    S.W. Pennsylvania
    2,250
    I looked it up in my 1947 edition of the welding encyclopedia and they have warnings of the critical nature of the way the boiler sections are made. I didn't study it but the first method they mention is OA welding with cast rods and complete preheat and post heat. The second way is OA brazing with bronze rod and then they mention arc process with copper rods. That is foreign to me.
    Last they do mention low carbon steel rod but don't elaborate on it.
    I just looked again and I think the copper, monel and bronze rods they mention for the arc process is using carbon arc process.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Jun 2006
    Maine
    732
    If I were you, I'd walk away from that job...
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Oklahoma
    737
    No offense intended here. If you are having to ask how, a boiler is not the place to practice or experiment.
    Sorry
    Griff
    Lake of the Ozarks MO
    3,594
    This could be about the stupidist thing I have suggested for awhile... but a 1/2" hole might be easily fixed simply by putting a nut and bolt in it. Or a pipe plug?
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Jul 2004
    Jackson, MI
    46
    I looked at the job today and walked away. It was a 1/2 inch rust hole with a spider web of cracks raadiating from it. It was only met to be a tempory fix if I could do anything untill the new boiler arrived at the end of the week. Thanks for your input.
    3,594
    Very smart move on your part. Stay in this biz long enuff and you'll walk away from a lot more.
    Miller WC-115-A
    Miller Spectrum 300
