Results 1 to 10 of 10
    Default How to build these type of tube mounts?
    Is this just bar that has been bored out?
    Feb 2008
    835
    It appears that thay have been drilled and spotfaced OR had a plug pressed inside of a short piece of tubing. Hard to tell as they are blurry and there is overspray on the face surface.
    Jun 2007
    San Jose,CA
    43
    Looks like a solid piece of round stock was drilled and turned. A piece of tubing was fishmouthed and then welded to the other piece.
    John
    Millermatic DVI
    Millermatic 375 xtreme
    And a brand new Syncro 200!!!
    3,655
    How many do you want????....Bob
    Well just 4 that would be nice but it be nicer if I can make myself too! But I can't drill out round stock like that big
    Queens NY
    1,547
    Why noy just use tubing??
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    3,655
    Quote Originally Posted by MrBurns View Post
    All you need is a metal lathe and some time...Bob
    Lightbulb
    well thats simple enough.
    seems like a tube with a plug center drilled would be the simplest / easy-est way if you don't have a lath. you could always drill the side of the tube to weld the plug in place threw the side. just get some tube and solid stock that fits tight, cut to fit.
    May 2008
    26
    had some fenders that had disconecting flaris that looked like that. it was a tube with a washer fit snug then tack welded on one side. used it so a bolt could join it then had plastic caps so you couldnt see
    Mpls, MN
    1,762
    My guess is that it's a washer welded inside the tubing. The reason being to prevent the bushings from distorting too much under load (which would change the drive line geometry).
    This is part of a high travel type off road suspension kit right?
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
